Forum Topic - Parallel port and irq7: (7 Items)
Hi there :)
I wrote a test application to work with the parallel port. The following code works, but after around 20k interrupts,
the programm freezes.
I place an external source with these parameter :
 - period = 100us
 - pulse duration = 20us
I also increase these parameters, but the problem persists.
Can someone help me?
#include <stdio.h>
#include <sys/neutrino.h>
#include <hw/inout.h>
#include <stdlib.h>
#include <stdint.h>
#include <sys/mman.h>
#define IRQ7                              0x07
#define BASE_ADDRESS_LPT1      0x378
#define INTR_BIT                        0x10
#define INIT_BIT			 0x04
#define MASK_OVLD                    0x01
#define MASK_RUN                      0x20
#define MASK_ACK                      0x10
struct sigevent event;
volatile int id1;
const struct sigevent *handler(void *area, int id);
int main(void){
	//variables
	int i;
	unsigned char reg;
	unsigned long lpt;
	ThreadCtl(_NTO_TCTL_IO, 0);
	event.sigev_notify = SIGEV_INTR;
        id1 = InterruptAttach(IRQ7, &handler, NULL, 0, 0 );
	lpt = mmap_device_io(3, BASE_ADDRESS_LPT1);
	reg = in8(lpt + 2);
	out8(lpt + 2, reg|INTR_BIT|INIT_BIT);
	while (in8(lpt + 1) & MASK_RUN){
		InterruptWait(0, NULL);
		i += 1;
		i %= 10000;
		printf("int %d.\n", i);
	printf("end of test\n");
        munmap_device_io(lpt, 3);
	InterruptDetach(id1);
	return 0;
const struct sigevent *handler(void *area, int id) {
	if (id == id1)
            return &event;
        else
            return NULL;
Re: Parallel port and irq7
I am really sorry, but found my error. It was because of the testing printf.
Have a nice day!
Cédric
Hi again ;)
Sorry to disturb you... I still have issues with interrupts and parrallel port.
In a few words :
My program await on a lpt interrupt (IRQ7), its period is 1ms and the pulse duration is half of this period.
An input pin gives the start and stop signal ("MASK_RUN").
Every time the program catch an interrupt, it toggles one output pin.
This pin state is displayed on a oscilloscope and after around fifteen seconds the execution freezes...
Is it a kind of overflow?
I read some internet pages about lpt port, but didn't find anything about particular servicing.
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <unistd.h>
#define IRQ7                              0x07
#define MASK_TOGGLE		 0x02
volatile int id1;
int main(void){
	unsigned char reg;
	unsigned long lpt;
	/*access to parallel port bytes... to write, read and configure...*/
       /* lpt irq activation */
	reg = in8(lpt + 2);
	out8(lpt + 2, reg|INTR_BIT);
	while(~in8(lpt + 1) & MASK_RUN);
	while(in8(lpt + 1) & MASK_RUN){
		reg = in8(lpt);
		out8(lpt, reg ^ MASK_TOGGLE);
	return 0;
  isr
	if (id == id1)
		return &event;
	else
		return NULL;
I also tried to replace InterruptAttach by InterruptAttachEvent without any succes :/.
Thanks for your help and hints!
Cédric
> 		reg = in8(lpt);
		InterruptUnmask(IRQ7, id1);
> 	return 0;
>   isr
> 	if (id == id1)
		InterruptMask(IRQ7, id1);
> 		return &event;
> 	else
> 		return NULL;
I would try the above - does it make a difference?
Thanks Aleksandar for your help :)
Unfortunately it didn't solve my problem.
Cédric
RE: Parallel port and irq7
This may seem like an obvious thing but is devc-par running? That would be the standard parallel port driver. When I was
 playing with a similar thing I seem to remember strange behaviour until I killed off devc-par.
Keith
From: Cédric Schaffter [mailto:community-noreply@qnx.com]
Sent: November 5, 2008 03:48
To: general-community
Subject: Re: Parallel port and irq7
Cédric
General
http://community.qnx.com/sf/go/post15948
Re: RE: Parallel port and irq7
Thanks Keith !
I perform a "slay devc-par" and it solves the problem!
Best regards,
Cédric
