10/22/2008 8:41 AM
post15391
Hi list!
I read the page http://www.qnx.co.jp/developers/docs/6.3.2/neutrino/prog/inthandler.html about interrupts.
Then I adapted the given example to handle keyboard irq.
But my system freezes.
#include <stdio.h>
#include <sys/neutrino.h>
#include <sys/syspage.h>
#include <semaphore.h>
#include <pthread.h>
#define IRQ1 1
struct sigevent event;
volatile unsigned counter;
sem_t end;
const struct sigevent *handler(void *area, int id) {
printf("ID : %d\n", id);
return(&event);
void * int_thread(void * cookie){
int i;
int id;
// Request I/O privity
ThreadCtl(_NTO_TCTL_IO, 0);
// Initialize event structure
printf("setting notification mode\n");
event.sigev_notify = SIGEV_INTR;
id=InterruptAttach(IRQ1, &handler, NULL, 0, 0 );
for( i = 0; i < 10; ++i ) {
InterruptWait( 0, NULL );
printf( "key hit\n" );
InterruptUnmask(IRQ1, id);
// Disconnect the ISR handler
InterruptDetach(id);
sem_post(&end);
return NULL;
int main() {
printf("application using irq1\n");
sem_init(&end, NULL, 0);
pthread_create(NULL, NULL, int_thread, NULL);
sem_wait(&end);
printf("normal termination...\n");
return 0;
I also have a few questions.
1. If I need to manage with multiples interrupts source. Should I create one thread and one ISR per source. Or can I use
one thread which will wait on many interrupts and then call the right ISR? If yes, how can I implement that?
2. In the handler function, the second parameter is "id", can someone explain me how the kernel informs this parameter?
Cédirc
10/22/2008 8:51 AM
post15392
Hi Cedric,
Could you please try it again w/o a printf() in an ISR!
Peter
From: Cédric Schaffter [mailto:community-noreply@qnx.com]
Sent: Wednesday, October 22, 2008 2:41 PM
To: general-community
Subject: Interrupt handling
Hi list!
#include <stdio.h>
#define IRQ1 1
sem_t end;
return(&event);
int i;
int id;
sem_post(&end);
return NULL;
int main() {
sem_wait(&end);
return 0;
Cédirc
General
http://community.qnx.com/sf/go/post15391
Re: RE: Interrupt handling
10/22/2008 9:14 AM
post15395
Thanks Peter, without the printf it works :)!
Do you know why this instruction made freeze?
Cédric
RE: RE: Interrupt handling
10/22/2008 9:28 AM
post15396
In general, it's not allowed to do kernel calls during an ISR.
Your code in the ISR will be executed with the kernel's stack.
As Thomas said, there are two main different approaches to register for an IRQ event with different flavors, you will
find many examples in the docs.
If you want to know about the possibility to use a function within an IRQ (kernel call or not), just look at the bottom
of the documentation for each function.
There you will find a table, explaining the context, the function could be used in.
E.g. For printf()
Classification:
ANSI, POSIX 1003.1
Safety:
Cancellation point No
Interrupt handler No
Signal handler Read the Caveats
Thread Yes
Peter
Sent: Wednesday, October 22, 2008 3:14 PM
Subject: Re: RE: Interrupt handling
Cédric
General
http://community.qnx.com/sf/go/post15395
10/22/2008 9:10 AM
post15393
Hi Cédric,
besides not doing kernel calls from an isr (better read the /entire/
documentation page for InterruptAttach :-), you also shouldn't need
to unmask the interrupt after getting the interrupt event - that's
only required when using InterruptAttachEvent() or if you explicitly
masked the IRQ in your interrupt handler. Which leads to your other
questions:
[snip]
> use one thread which will wait on many interrupts and then
You do not need an extra thread to handle interrupts. You'll usually
dedicate one thread to interrupt handling in so it can quickly react
to hardware events. Just as well you do not need an extra thread per
interrupt source. You could call InterruptAttach() multiple times
for different IRQs, each time providing the same ISR. For handling
different devices from the same code, you might use the data area
you can provide to the handler via the "area" argument.
It is the interrupt id that was returned to your program from
InterruptAttach() . You would, for example, need it if you wanted
to mask the IRQ in your interrupt handler and had interrupt masking
tracked (which you don't right now, but usually always should - see
the _NTO_INTR_FLAGS_TRK_MSK flag to InterruptAttach() )
- Thomas
> Thanks,
> Cédirc
Re: AW: Interrupt handling
10/22/2008 9:53 AM
post15401
Thanks for all this detailled information Peter and Thomas!
These interrupts managements are more clear to my mind now.
