Forum Topic - Periodic tasks creation:
Hi!
I am a new user of QNX. Actually, I am working on my diploma project which consists to compare three rtos (qnx, rtos32
and xenomai).
I searched informations about tasks, and especially about periodic tasks.
Is there a trivial way to perform them? For example an instruction which make sleep the task till the next activation by
 the scheduler?
At this moment I use semaphores. Each thread waits on a specific semaphore and another thread uses "sem_post(&rtTaskN)"
for all the threads after a specified period in a timer.
I also have another question about cpu clock, if I specify "CLOCK_REALTIME" in the instruction "timer_create", which
system clock will I use? The RTC clock of the system@32kHz or a cpu internal clock with a greater precision?
Thanks for your help.
Re: Periodic tasks creation
Hello Cédric,
If you are looking for a way to “make sleep the task till the next activation by the scheduler”, please check
description of SchedYield(), SchedYield_r():
http://www.qnx.com/developers/docs/6.3.2/neutrino/lib_ref/s/schedyield.html
CLOCK_REALTIME refers to a high-speed (MHz range) CPU internal clock.
Yuriy
Thanks for your answer Yuriy ! It helped me much :)
Hi List,
I get another problem with my application. I would like to generate a signal with a timer, and synchronize one thread
with this timer.
Actually, it's like if my timer_handler can't catch the signal.
Did I miss some instructions or did something wrong?
Thanks.
#include <stdlib.h>
#include <stdio.h>
#include <signal.h>
#include <semaphore.h>
#include <pthread.h>
#include <time.h>
sem_t rtClockSem;
sem_t startStopSem;
pthread_t tSubRate1Desc;
struct itimerspec paramTimer;
struct sigevent event;
timer_t timerDesc;
int i = 0; /*just for test and debug*/
void * tSubRate_1(void * cookie)
  while (1) {
 	sem_wait(&rtClockSem);
	printf("Hello...\n");
	i += 1;
	if (i > 5)
		sem_post(&startStopSem);
void timer_handler(int sig){
	int status;
	if (sig == SIGRTMIN){
		status = sem_post(&rtClockSem);
		if (status != 0)
			printf ("Semaphore error : %d\n", status);
		/*signal association*/
		signal(SIGRTMIN, timer_handler);
  		if (status != 0)
  			printf("error while signal association \n");
	int status;
	status = sem_init(&startStopSem, NULL, 0);
 	if (status != 0)
    	printf("Error creating semaphore : %d\n", status);
	status = sem_init(&rtClockSem, NULL, 0);
  	if (status != 0)
	status = pthread_create(&tSubRate1Desc, NULL, tSubRate_1, NULL);
  	if (status != 0)
    	printf ("Error creating task : %d\n", status);
  	status = timer_create(CLOCK_REALTIME, &event, &timerDesc);
  	if (status != 0)
  		printf("Error creating timer : %d\n", status);
        paramTimer.it_interval.tv_sec = 1;
  	timer_settime(timerDesc, 0, ¶mTimer, NULL);
	sem_wait(&startStopSem);
	printf("End...\n");
	return EXIT_SUCCESS;
AW: Periodic tasks creation
Hi Cédric,
you missed a few minor things - first of all, you need to initialize the struct sigevent prior to passing it to
timer_create(). Use SIGEV_SIGNAL_INIT to do so (see below).
Further, the struct itimerspec provided to timer_settime must be completely initialized, and its  it_value  member must
be != 0.0, otherwise the time won't run.
See below for a revised (working) version of your app. I removed the clock semaphore; you can just use  sigwait()  in
your thread to synchronize on the signal. Saves a lot of overhead, too.  Oh, and BTW - you don't need to reattach a
signal handler within itself (like you do in some other OSes), so calling  signal()  in your  timer_handler()  function
isn't required.
Hope this helps.
Cheers,
- Thomas
#include <stdlib.h>
#include <stdio.h>
#include <signal.h>
#include <time.h>
sem_t		startStopSem;
void *tSubRate_1( void * cookie ) {
	sigset_t  sigs;
	int  sig;
	while (1) {
		sigemptyset( &sigs );
		sigaddset( &sigs, SIGRTMIN );
		sigwait( &sigs, &sig );
		i += 1;
		if ( i > 5 )
			sem_post( &startStopSem );
	timer_t  timerDesc;
	int  status;
	if (status != 0)
	status = pthread_create( &tSubRate1Desc, NULL, tSubRate_1, NULL );
	if (status != 0)
	SIGEV_SIGNAL_INIT( &event, SIGRTMIN );
  	status = timer_create( CLOCK_REALTIME, &event, &timerDesc );
  	if (status != 0)
	paramTimer.it_value.tv_sec = 1;
	paramTimer.it_value.tv_nsec = 0;
	paramTimer.it_interval.tv_nsec = 0;
  	timer_settime( timerDesc, 0, ¶mTimer, NULL );
	sem_wait( &startStopSem );
	printf("End...\n");
> -----Ursprüngliche Nachricht-----
> Von: Cédric Schaffter [mailto:community-noreply@qnx.com]
> Gesendet: 19 September 2008 11:02
> An: general-community
> Betreff: Re: Periodic tasks creation
> Hi List,
> with this timer.
> Thanks.
> #include <stdlib.h>
> #include <stdio.h>
> #include <signal.h>
> #include <time.h>
> sem_t rtClockSem;
> sem_t startStopSem;
> timer_t timerDesc;
>   while (1) {
> 	i += 1;
> 	if (i > 5)
> 	int status;
> 		if (status != 0)
>   		if (status != 0)
> 	int status;
>  	if (status != 0)
Re: AW: Periodic tasks creation
Great! It works well!
Thanks for your help Thomas.
Hi list,
I would like to know if there's a way to increase the resolution of this timer?
Actually, I need to perform tasks each tenth micro-seconds, but with this implementation, I don't have an accuracy
better than around 1millisecond.
I read the article about the function Clockperiod and tried to implement like this :
  struct _clockperiod newRes;
  struct _clockperiod oldRes;
  newRes.nsec = 1000;
  newRes.fract = 0;
  status = ClockPeriod(CLOCK_REALTIME, &newRes, &oldRes, 0);
  if (status < 0) {
    printf("Error setting CLOCK_REALTIME new period %ld\n", newRes.nsec);
    exit(-1);
Doing like this, I hoped to get a resolution of 1micro-second.
Is it the best way to increase the resolution or should I implement interrupts with the 8254 internal component?
Can someone help me ?
Thanks.
Cédric Schaffter wrote:
>  Hi list,
>  this timer?
>  this implementation, I don't have an accuracy better than around
>  1millisecond.
[ Code sample snipped ]
>  Can someone help me ? Thanks.
That would be how you would do it if you wanted to use the OS timing
facilities for general dispatch and scheduling of your tasks.  However at
that rate you will start chewing more CPU for general scheduling checks
and if the system you are running on doesn't have the free cycles or the
horsepower then it might not be the best route.
If you can re-program other hardware timers to trigger an interrupt that
you specifically handle, that may be a better (more efficient) way to
trigger
your periodic code and leave the general system scheduling at the 1ms
clock resolution.
Hope this helps,
 Thomas
Thanks Thomas for your answer !
So first I will try to use the 8254 programmable interval timer. And if I don't have efficient results, I will add an
extern timer card to my system.
Best regards,
Cédric
