08/16/2024 8:33 AM
post122597
Hi QNXers:
I enter a wired issue about tcpdump timestamp: tcpdump timestamp is almost always larger than application timestamp
when receive the package.
Using below steps can reproduce the issue on QNX qemu virtual machine:
QNX: start a netcat server with shell: ./netcat -lp 8888 -e /bin/sh
then start tcpdump: tcpdump -tt -s0 -i vt0 port 8888 -X
PC: nc to qnx: nc 172.31.1.110 8888, then enter date +%s.%N to get QNX timestamp
From the attached picture:
T1: 1723810894.254562 receive the date command packet, then tcp package passing to netcat server
T2: 1723810893.643000000 netcat server receive date command, run the command get this timestamp
Why T2 < T1? this is normal? From qnx documents: https://www.qnx.com/developers/docs/7.0.0/index.html#com.qnx.doc.
neutrino.utilities/topic/t/tcpdump.html
By default, all output lines are preceded by a timestamp. The timestamp is the current clock time, in the form hh
:mm:ss.frac and is as accurate as the kernel's clock.
The timestamp reflects the time io-pkt first saw the packet.
Hope some guru can give some suggestions about this issue, thanks.
Version Info:
QNX SDP 7.1
tcpdump --version
tcpdump version 4.9.3
libpcap version 1.9.1
OpenSSL 1.1.1k 25 Mar 202
netcat: https://sourceforge.net/projects/netcat/files/
