Build GDB Source Code for QNX (QNX App Debugging alternative)
01/26/2024 4:50 AM
post122466
I’ve retrieved the GDB source from QNX CVS.
The error message indicates that the linker (ld) cannot find the definitions for various functions, such as
i386_linux_read_description, amd64_linux_read_description, amd64_collect_fxsave, amd64_collect_xsave,
amd64_supply_fxsave, amd64_supply_xsave, amd64_linux_gregset_reg_offset, amd64_supply_fxsave, and amd64_collect_fxsave.
1) Where to find the source code of above function or is it available in some library how to link that library?
2) IS any script availbe to use for the same?
For Example : Using Standard GDB with pdebug:While a standard GDB client wouldn't directly work with pdebug, it's
possible to bridge the gap using additional tools:
QNX SDK: The QNX Software Development Platform (SDK) includes a wrapper script that allows executing standard GDB
commands over the pdebug connection. This essentially translates GDB commands into the pdebug protocol, enabling limited
use of regular GDB with pdebug.
3)Custom scripts: With advanced knowledge of both GDB and pdebug protocols, it's possible to write custom scripts or
wrappers that translate commands and bridge the communication gap.
Is any customer scripts availbe for use ?
4) We just need to avoid QNX Debugger. We just want to use open source debugger for QNX application if any other
approched can u please inform?
