Forum Topic - Add additional directories to PATH and LD_LIBRARY_PATH at startup: (2 Items)
My target system is a PC running Neutrino natively, but I also want to do this in a vmware image.
I am trying to add two entries to the environment variables PATH and LD_LIBRARY_PATH so that I can keep my binaries and
libraries in separate locations from the normal /bin and /lib paths.
I have read the help on "How Neutrino Starts" and understand that I cannot use rc.local to add these as a different
shell gets started by init.
I could do this in the .profile of the user and export it, but I don't think this allows Momentics to see the libs when
debugging or running.
Is there someplace in the startup scripts (before someone logs in) that I can set these variables and have them be
effective system wide?
Thanks for the help.
- Mike
Re: Add additional directories to PATH and LD_LIBRARY_PATH at startup
You can update these in your build file on the procnto line, and set new default values:
http://www.qnx.com/developers/docs/6.3.2/neutrino/utilities/m/mkifs.html
The contents of the host file that this attribute applies to are parsed to discover the bootstrap executables used to
bring up the system. Each line identifies one bootstrap executable:
    * The first executable must be the QNX Neutrino startup executable (startup-*) that's appropriate for the target
system. For more information, see Startup programs (startup-*) in the Utilities Summary.
    * The last must be procnto. Specifying the PATH and LD_LIBRARY_PATH environment variables before procnto sets their
default values in the OS image.
ie PATH=/bin:/sbin:/mybins LD_LIBRARY_PATH=/lib:/usr/lib:/mylibs procnto
Hope this helps.
Peter
