Forum Topic - C++ Overloaded method inheritance question.:
Im am unable to get the following to compile. It errors in main on the first Call function. Does a derived class hide
methods of the same name with a different sig? I dont want to have to use Base1::Call...
Without going into too much detail I need to be able to build up a class, this is done with template and template
specialisations, with an overloaded function that is then called in the mannor below.
class Base1 {
public:
	void Call(){}
class Base2 : public Base1 {
public:
	void Call(int i){}
int main(int argc, char **argv){
	Base2 func;
	func.Call();
	func.Call(5);
	return 0;
..\src\main.cpp:15: error: no matching function for call to `Base2::Call()'
..\src\main.cpp:9: note: candidates are: void Base2::Call(int)
Is there a way to get this to work?
Kind Regards,
Paul
Re: C++ Overloaded method inheritance question.
Base1:Call() needs a void in the parameter list.
You will need either a Base2::Call(void) or set a default value for i to
Base2::Call(int i=0)
Paul Wakefield wrote:
> first Call function. Does a derived class hide methods of the same name
> class, this is done with template and template specialisations, with an
> class Base1 {
> public:
>         void Call(){}
> public:
>         void Call(int i){}
>         Base2 func;
>         func.Call();
>         func.Call(5);
>         return 0;
`Base2::Call()'
> Kind Regards,
> Paul
> http://community.qnx.com/sf/go/post8299
cburgess@qnx.com
Add this line in Base2's public section:
using Base1::Call;
So, the complete code will be:
#include <iostream>
class Base1 {
public:
	void Call(){ std::cout << "call()\n"; }
public:
	using Base1::Call;
	void Call(int i){ std::cout << "call(int)\n"; }
	Base2 func;
	func.Call();
	func.Call(5);
	return 0;
