Forum Topic - dvfsmgr-imx6 revision Unknown Revision: (5 Items)
Dear:
1:
My Board: Detected i.MX6 Dual/Quad, revision TO1.5
2:
But: dvfsmgr-imx6 -s -v -c /usr/autolink/conf/dvfs_imx6q_996mhz.conf
slogginfo:
Jan 01 00:08:15    5    90     0 DVFS:print_chip_info(729): Detected i.MX6 Dual/Quad, revision Unknown Revision
Jan 01 00:08:15    5    90     0 DVFS:init_cpu_info(1111): Ignoring speed grade (SoC capable of running at 996MHz)
Jan 01 00:08:15    5    90     0 DVFS:init_cpu_info(1159): Working with 792 MHz table, number of levels: 3
Jan 01 00:08:15    5    90     0 DVFS:get_next_level_from_file(492): Parsed level: 0, 100, 70, 125, 123
Jan 01 00:08:15    5    90     0 DVFS:get_next_level_from_file(492): Parsed level: 1, 80, 45, 125, 123
Jan 01 00:08:15    5    90     0 DVFS:get_next_level_from_file(492): Parsed level: 2, 60, 30, 125, 123
Jan 01 00:08:15    2    90     0 DVFS:get_next_level_from_file(430): Error in the config file. Maximum level should not
exceed 3
Jan 01 00:08:15    2    90     0 DVFS:main(1319): Could not initialize DVFS table
Jan 01 00:08:15    5    90     0 DVFS:dvfs_shutdown(1227): Shutdown Completed Successfully
So i think the dvfsmgr-imx6 is too old
can i get the dvfsmgr-imx6 source code ?
Re: dvfsmgr-imx6 revision Unknown Revision
Hi
Please tell us the QNX version you are using: 6.5, 6.6 or 7.0?
Also, I have seen on some dvfs scripts that an additional file is being loaded /etc/dvfs/config/imx6/dvfs_pwrtbl_imx6.
conf. Maybe that is missing from your setup?
Albrecht
Dear:
qnx 6.6
the /etc/dvfs/config/imx6/dvfs_pwrtbl_imx6.conf isn't required
My Board revision is TO1.5
But dvfsmgr-imx6 Detected  Unknown Revision
i think  dvfsmgr-imx6 Detected  max revision is 1.3
So i want get the dvfsmgr-imx6 source code
where the source code
You need to contact QSS via Support portal, the source is not released to the community to my best belief.
-Al
