Forum Topic - No output on terminal for TI Jacinto 6 EVM Board: (5 Items)
Our components:
• Vayu EVM CPU Board
• JAMR3 Application Board
• 10.1 inch LCD/TS Daughter Board
 To boot Jacinto 6 EVM board from U-Boot:
1. Connect theJacinto 6 EVM target board to host system.
2. On host machine, start terminal program with these settings:
Baud: 115200
Bits: 8
Stop bits: 1
Parity: none
3. Connect the Jacinto 6 EVM board to the power supply, then push the PWR RESET button.
But I can't see the output from U-Boot appear on the host system console.
I have copied three files to micro SD card:
ifs-dra74x-vayu-evm.bin
MLO
u-boot.img
SYSBOOT[0:15] (SW2[1-8] SW3[1-8]) = 01100000 10000001
SW5[1:10] = 1010100000
Hubery.
Re: No output on terminal for TI Jacinto 6 EVM Board
You must ensure that the partition on the SD card is set to "Active" and that MLO is the first file copied to the SD
card after a fresh format of the SD Card.
Hi Dave,
I can boot GLSDK u-boot with the board. But can't boot the ti-j6-dra74x_vayu-evm u-boot from QNX bsp.
Did SD card need to format two partitions? or only one active partion to load images.
one fat32 partion name "boot" another ext3/4 partition name "rootfs" .
> Hi Dave,
> images.
Have solved the problem.
Are you able to use LCD with Jacinto 6 EVM?
If yes then , how ?
