Booting BeagleBone Black from Micro SD card.
01/22/2015 9:41 PM
post113048
Hello All,
I am trying to boot QNX from the MicrSD card slot on the BBB. Depending on what you read on the web this can either
occur quickly or can take up to a half an hour.
I copied (naively using windows explorer) MLO, u-boot and ifs-ti-am335x-beaglebone to a active healthyt sector on the
SD card. I had to try a couple of SD cards because windows would not let me make the partition active, using the
alternative described by QNX didn't seem to help. ( It all depended on whether or not you believed the asterisk that
appeared in the command window but not indicated as active in the Disk Management tool. But enough of that) I
eventually found one we had used for Linux that had the active partition. I removed all the other files and only copied
the three files I mention above. When I start the sequence what happens is that I have a continual string of the
character "C" being written to putty on my computer via the usb to ftdi cable.
As I mentioned I have putty running and am seeing continual line of C's being streamed to the terminal window.
I'd appreciate it if you could let me know the secret to getting this board to boot QNX. I have to port our code and do
some timing measurements. Thanks. Jim
