Forum Topic - Is there any graphic library?: (5 Items)
Hi.
I am planning to port our product on QNX platform.
I am responsible of UI part.
When I tried to find UI library, there was Photon in previous version (6.5).
But, I could not find any UI library to implement editor, button and etc in 6.6 version.
Could you tell me how I can do what I want.
Re: Is there any graphic library?
The graphics system in 6.6 is called Screen. You can find the documentation for it here:
http://www.qnx.com/developers/docs/660/topic/com.qnx.doc.screen/topic/manual/cscreen_about.html?cp=1_1_6
Thanks for your answer.
Screen is just for window, display and etc.
But, there is no support for widget elements like button, editor and ...
Photon had apis to support them.
http://www.qnx.com/developers/docs/qnx_4.25_docs/photon114/prog_guide/tutorls.html
If widget elements are not supported, should we implement them with OpenGL?
You can use Qt, HTML5, or Crank Storyboard!
Cheers,
- Malte
You can run JamaicaVM on QNX which supports the OpenJDK.
This gives you SWING graphics support.
You can also use our application framework environment, JamaicaCAR.
This is useful for application such as automotive infotainment and similar.
David Beberman
