pure virtual method called
03/05/2014 10:12 AM
post109205
I am currently trying to debug a very elusive problem. When running our code under Momentics, about every 10th run I
will get the following error on the console:
terminate called without an active exception
and then my programs exits as if it terminated normally. The debugger also terminates normally. My program is multi-
threaded. Since no exception or signal is being generated, the debugger doesn't break. This happens regardless if the
program is compiled for Debug or Release. I need to set a breakpoint where this message is being generated, but this is
happening in the bowels of the run-time libraries. How do I debug this problem?
I am using QNX 6.5.0 and Momentics 4.7.0
