Forum Topic - Question about socketpair:
Does anyone know of any way to write to a socket and block until the data has been read at the other end?
Apparently, the socket has some sort of receiving/sending buffer (SO_RCVBUF/SO_SNDBUF options), I was thinking maybe we
can change the value to block write(). So I tried setting the buffer size to 1 byte, and for some reason it didn't work:
 setsockopt() returned correctly, but write() function was not blocked anyway. I also tried buffer size 16 and 64 byte,
they didn't work either.
Any idea?
Thanks.
//*************** Code ***************************
    int size = 1;
    if (setsockopt(fda[0], SOL_SOCKET, SO_RCVBUF, &size, sizeof(int)) < 0){
        cout << "something is wrong" << endl;
    if (setsockopt(fda[1], SOL_SOCKET, SO_SNDBUF, &size, sizeof(int)) < 0){
RE: Question about socketpair
No you can't, that's not how TCP/IP is designed.
Sent: Wednesday, April 16, 2008 5:45 PM
To: general-community
Subject: Question about socketpair
(SO_RCVBUF/SO_SNDBUF options), I was thinking maybe we can change the value
reason it didn't work: setsockopt() returned correctly, but write() function
was not blocked anyway. I also tried buffer size 16 and 64 byte, they didn't
work either.
Any idea?
Thanks.
    int size = 1;
General
http://community.qnx.com/sf/go/post6938
Re: RE: Question about socketpair
I was actually trying to use it as a local socket stream, as
socketpair(AF_LOCAL, SOCK_STREAM, 0, fda) ;
