Forum Topic - O_DSYNC option on serial port : (3 Items)
I was writing a program communicating via COMM with read/write, and thinking of setting the comm to synchronous mode,
such that write() function won't return until all data in the buffer has been sent. So, I tried to set the O_DSYNC flag
by calling fcntl() function. But apparently it doesn't work, fcntl function call return with errorno:22 (/* Invalid
argument*/).
Anyone has any idea? I guess qnx does't support O_DSYNC flag for serial port, is that right?
Any idea how to walk around this: how to write() comm in a synchronous mode?
Attached is the code I used.
Thanks.
//*************** Code ***************************
#include <iostream>
#include <fstream>
#include <sys/types.h>
#include <sys/socket.h>
#include <unistd.h>
#include <pthread.h>
#include <fcntl.h>
#include <stdarg.h>
#include <termios.h>
#include <time.h>
#include <errno.h>
using namespace std;
int main (int argc, char **argv)
	int serf = open("/dev/ser1", O_RDWR );
	if (serf == -1)
		cout << "Fail to open COM." << endl;
		exit(1);
	int retval = fcntl(serf, F_SETFL, O_DSYNC );
    if( retval == -1 ) {
        printf( "error setting stdout flags, with errorno=%d\n", errno);
        return EXIT_FAILURE;
	ifstream iFile;
	char* iFileName = "/etc/printers/epijs.cfg";
	iFile.open(iFileName, ios::binary);
	if(!iFile.is_open())
		cout << "Error opening input file named: " << iFileName << endl;
		exit (1);
	int wcount;
	while(!iFile.eof())
		char buffer[132];
		iFile.read(buffer, 132);
		wcount=iFile.gcount();
		if (write(serf, buffer, wcount) != wcount)
			cout << "Write error!" << endl;
			exit (1);
	iFile.close();
	close(serf);
	return EXIT_SUCCESS;
Re: O_DSYNC option on serial port
thinking of setting the comm to synchronous mode, such that write() function
the O_DSYNC flag by calling fcntl() function. But apparently it doesn't
work, fcntl function call return with errorno:22 (/* Invalid argument*/).
mode?
I'm not sure if it's a bug or not that O_DSYNC wasn't supported, but check
out the tcdrain() function - it'll do what you wanted.
Thanks Brian,
That seems exactly what we want.
