Forum Topic - To recover corrupted file system: (2 Items)
My QNX virtual machine was terminated unexpectedly when the host OS crashed. Since then, QNX starts saying:
    Read-only file system
that I assume due to an inconsistency on the file system (cf: http://askubuntu.com/questions/197459/read-only-file-
system). I've been trying to use QNX equivalent of `fsck` such as chkfsys, chkdosfs or chkqnx6fs but haven't really
figured out what arguments I should give especially with virtual machine entity. How can I run those commands? Or how
can I recover the file system?
Thank you.
RE: To recover corrupted file system
> -----Message d'origine-----
> De : Isaac Isao Saito [mailto:community-noreply@qnx.com]
> Envoyé : 20 juin 2013 07:24
> À : general-community
> Objet : To recover corrupted file system
> http://askubuntu.com/questions/197459/read-only-file-system). I've been
> but haven't really figured out what arguments I should give especially with
> virtual machine entity. How can I run those commands? Or how can I recover
> the file system?
First you need to make sure the host filesytem is ok.  In the guest, QNX in your case, you treat it just as a normal
machine, the fact that it`s a virtual machine is irrelevant. First you need to figure out if QNX is using a qnx4 or qnx6
 filesytem.  You can tell be running the mount command, no argument,. For each partition fount it will show the type.
If it`s a qnx4 filesystem you use chkfsys, if it`s qnx6 use chkqnx6fs !  For the argument read the doc on each ;-)  Also
 in the case check out the doc to chattr +-snapshot as you might need it.
> Thank you.
> http://community.qnx.com/sf/go/post102471
> To cancel your subscription to this discussion, please e-mail general-
> community-unsubscribe@community.qnx.com
