Forum Topic - A question about digital sensor: (3 Items)
Hi, it is not a qnx question, but a qnx application consultation.
Now I have a qnx box and a digital temperature sensor. The box have 10 DI/DO ports, 2 serial ports. How can I get the
sensor's sampling temperature data by qnx programming? Need I buy an additional board?
Any suggestion will greatly appreciated.
RE: A question about digital sensor
That depends on the interface of the digital sensor, serial port, USB etc?  Then you need to know the protocol and write
 a piece of code that will handle the data.
> -----Message d'origine-----
> De : Allen Chen [mailto:community-noreply@qnx.com]
> Envoyé : 5 juin 2013 11:38
> À : general-community
> Objet : A question about digital sensor
> DI/DO ports, 2 serial ports. How can I get the sensor's sampling temperature
> http://community.qnx.com/sf/go/post102028
> To cancel your subscription to this discussion, please e-mail general-
> community-unsubscribe@community.qnx.com
Re: RE: A question about digital sensor
Hi Mario, it is a Arduino compatible SHT1x humidity and temperature sensor. There are six pins, i.e. DATA, CLOCK, 2 VCCs
 and 2 GNDs. I read the source code of Arduino encapsulated SHT1x class.Mainly it uses two PINs, DATA and CLOCK. It set
pin DATA as input and pin CLOCK as ouput, and then use digitalWrite and digitalRead APIs to read humidity and
temperature data.
I don't know whether it can be read via PC serial port. If yes, it really convenient for us to use this sensor on QNX
box.
The attachment is Arduino SHT1x library class. Please have a look. Thank you.
Attachment: Compressed file SHT1x_Arduino Compatible with Arduino IDE 1.0 or later.zip 5.35 KB
