Forum Topic - New AMPRO Board Problem: (1 Item)
We are using 6.5 and our target is an AMPRO x86. We had been using their 700 Littleboard, but because it has been
discontinued we had to upgrade to their 735. They had previously released an 800 board which worked fine, but it was
discontinued and replaced with the 735. We are having problems maintaining connection with this board. We are also
experiencing memory problems.
AMPRO has seen this a couple other times with QNX/LINUX operating systems. They suspect we are writing to the area of
memory where the Ethernet ports are located. A possible solution: customized driver.
I was wondering if anyone else is seeing this or is familiar with the problem. Maybe there is a solution in the QNX side
