cannot bootstrap: fails with files not found error
02/25/2013 12:53 PM
post99520
Hello.
I am trying to bootstrap my local copy of HEAD_650.
First I remove the "bootstrap/work" directory.
Second, I run bootstrap script which end if the following error:
# ./bootstrap
===> bootstrap command: ./bootstrap
===> bootstrap started: Mon Feb 25 12:48:00 EST 2013
Working directory is: /root/tmp/QNX6.5_SVN/HEAD_650/pkgsrc/bootstrap/work
===> running: /usr/bin/sed -e 's|@DEFAULT_INSTALL_MODE@|'0755'|' /root/tmp/QNX6.5_SVN/HEAD_650/pkgsrc
/sysutils/install-sh/files/install-sh.in > /root/tmp/QNX6.5_SVN/HEAD_650/pkgsrc/bootstrap/work/bin/in
stall-sh
===> running: /bin/chmod +x /root/tmp/QNX6.5_SVN/HEAD_650/pkgsrc/bootstrap/work/bin/install-sh
===> Creating default mk.conf in /root/tmp/QNX6.5_SVN/HEAD_650/pkgsrc/bootstrap/work
===> running: /bin/sh /root/tmp/QNX6.5_SVN/HEAD_650/pkgsrc/bootstrap/work/bin/install-sh -d -o root -
g root /root/tmp/QNX6.5_SVN/HEAD_650/pkgsrc/bootstrap/work/sbin
g root /root/tmp/QNX6.5_SVN/HEAD_650/pkgsrc/bootstrap/work/share/mk
===> Bootstrapping mk-files
===> running: (cd /root/tmp/QNX6.5_SVN/HEAD_650/pkgsrc/pkgtools/bootstrap-mk-files/files && env CP=/b
in/cp OPSYS=QNX MK_DST=/root/tmp/QNX6.5_SVN/HEAD_650/pkgsrc/bootstrap/work/share/mk ROOT_GROUP=root
ROOT_USER=root SED=/usr/bin/sed SYSCONFDIR=/usr/pkg/etc /bin/sh ./bootstrap.sh)
./bootstrap: cd: /root/tmp/QNX6.5_SVN/HEAD_650/pkgsrc/pkgtools/bootstrap-mk-files/files - No such fil
e or directory
===> exited with status 1
aborted.
Anybody know how to fix this problem?
Thanks.
HS.
