Forum Topic - Native SP1 installation: (2 Items)
Is there an 6.5.0 installation image available that includes the SP1 updates. The two step installation of the SP1
updates are very inconvient when have to initiallly install 6.5.0 Neutrino first without the updates. I either have such
 limited support or cannot even install the OS. That means I have to build the OS on another system first and use a
custom build file.
If I had a Neutrino installation disk with the SP1 updates already in the image file I would not have such a mess to
work with.
Re: Native SP1 installation
No, there isn't. I'm afraid your approach isn't what QNX made the installation for. The 6.5 CD/DVD-based *Neutrino*
installation is for self-hosted development - not for your target. You usually would install your development only once,
 and then install SP1, and go from there.
>  the OS on another system first and use a custom build file.
That is the *standard* way it's done today. You shouldn't install the QNX self-hosted dev seat on a target. Too much
gets installed. If you require a CD based installation, refer to the Technote in the docs called "How to create a
Runtime Kit from the QNX Software Development Platform".
- Malte
