Trackers
Trackers
Forum Topic - On linux, which "recurse.mk" is used?: (8 Items)
Question: on my linux, why does "make" use "/opt/qnx650/target/qnx6/usr/include/mk/recurse.mk" instead of "$QNX_TARGET/
usr/include/mk/recurse.mk"?
The document (http://www.qnx.com/developers/docs/6.4.1/neutrino/prog/make_convent.html) says:
The recurse.mk file resides under $QNX_TARGET/usr/include/mk. This directory contains other files that are included
within makefiles. Note that while the make utility automatically searches $QNX_TARGET/usr/include, we've created
symbolic links from there to $QNX_TARGET/usr/include/mk.
However, in the tests on my linux, it looks that "make" uses "/opt/qnx650/target/qnx6/usr/include/mk/recurse.mk" instead
 of "$QNX_TARGET/usr/include/mk/recurse.mk". Why?
Details:
1. There are "recurse.mk" files under both "$QNX_TARGET/usr/include/mk/recurse.mk" and "/opt/qnx650/target/qnx6/usr/
2.The QNX env variables are:
QNX_TARGET_SDK=/opt/qnx650/target/qnx6
QNX_CONFIGURATION=/etc/qnx
QNX_JAVAHOME=/opt/qnx650/_jvm
QNX_TARGET=/home/builder/p4/myProject/ap/msm/deckard65x/developer/trunk/target/qnx6
QNX_HOST=/opt/qnx650/host/linux/x86
3. I did following tests:
a. modify "/opt/qnx650/target/qnx6/usr/include/mk/recurse.mk" by adding a line "$(info QNX_TARGET=$(QNX_TARGET))", run "
make install", then we can see the message:
b. delete  "/opt/qnx650/target/qnx6/usr/include/mk/recurse.mk" and run "make install" then we can see:
Makefile:4: recurse.mk: No such file or directory
make: *** No rule to make target `recurse.mk'.  Stop.
Thank you,
Raymond
Re: On linux, which "recurse.mk" is used?
Check the MAKEFLAGS environmental variable.
/usr/include/mk/recurse.mk"?
instead of "$QNX_TARGET/usr/include/mk/recurse.mk". Why?
> Details:
 "make install", then we can see the message:
> Thank you,
> Raymond
> http://community.qnx.com/sf/go/post90318
It's because your MAKEFLAGS envvar still points at /opt/qnx650 and not
-I$QNX_TARGET/usr/include
Ryan Mansfield
Sean  and Ryan,
I just verified that after changing MAKEFLAGS=-I$QNX_TARGET/usr/include, I can see "make" search "recurse.mk" under "$
QNX_TARGET/usr/include" instead of ""/opt/qnx650/target/qnx6/usr/include".
Thank you! :)
I have installed qnx650 & qnx SP1 on Ubuntu 14.04.
I try to compile libdce from here: http://git.omapzoom.org/?p=repo/libdce.git;a=summary
I have set the variables from README:
~/libdce/libdce$ export QNX_ROOT=/opt/qnx650
~/libdce/libdce$ export QNX_HOST=${QNX_ROOT}/host/linux/x86
~/libdce/libdce$ export LD_LIBRARY_PATH=${QNX_HOST}/usr/lib
~/libdce/libdce$ export QNX_TARGET=${QNX_ROOT}/target/qnx6
~/libdce/libdce$ export MAKEFLAGS=-I${QNX_TARGET}/usr/include
~/libdce/libdce$ export QNX_CONFIGURATION=/etc/qnx
~/libdce/libdce$ export QNX_JAVAHOME=${QNX_ROOT}/_jvm
~/libdce/libdce$ export PATH=${QNX_HOST}/usr/bin:${PATH}:${QNX_CONFIGURATION}/bin
~/libdce/libdce$ eval `qconfig -n "QNX Software Development Platform 6.5.0" -e`
When I run:
~/libdce/libdce$ make -f Makefile.qnx install
The output is:
Makefile.qnx:3: /opt/qnx650/target/qnx6/usr/include/recurse.mk: No such file or directory
I have symbolic link to recurse.mk in
~/libdce/libdce$ ls /opt/qnx650/target/qnx6/usr/include
recurse.mk points to mk/recurse.mk that is also a symbolic link
I have read older post regarding this issue and still doesn't work.
Thank you
Raymond,
Thank you for your promt reply.
Adelina Stanciu,
You were speaking about building dce_test. Could you please let me know the procedure to be followed.
I have followed the README and did the required settings.
But i could not run dce_test succesfully.
-Srinivas.
Hi Raymond,
you were able to build and run dce_test ?
Could you please let me know the procedures you followed to build and run libdce and dce_test?
Srinivas.
RE: On linux, which "recurse.mk" is used?
I don't remember I built dce_test before.
Raymond
From: Srinivas M [mailto:community-noreply@qnx.com]
Sent: Tuesday, December 02, 2014 3:29 AM
To: general-community
Subject: Re: On linux, which "recurse.mk" is used?
Hi Raymond,
Srinivas.
General
http://community.qnx.com/sf/go/post112503
To cancel your subscription to this discussion, please e-mail general-community-unsubscribe@community.qnx.com
