Forum Topic - Cancelling/slaying/killing reply blocked threads.:
Hi there,
I have a setup where I have an application that sends a request to a Resource Manager.  This ResMgr doesn't reply to the
 message until something has occurred that requires a reply.  This concept is talked about in some of the IPC related
pages on this site.  As long as everything is running this concept works really well for my situation, however in the
process of debugging and general implementation work I like to Ctrl-C and/or slay my application that is sending the
message.  When I attempt this pidin shows me that the thread i have doing the MsgSend is still blocked on REPLY and i'm
unable to fully kill the application.  Today I need to slay both the sending application, and the ResMgr that does the
actual replying.
So my question is, how can I have all my application's threads terminated when I use "slay" or Ctrl-C?
Josh
Re: Cancelling/slaying/killing reply blocked threads.
On Wed, Feb 27, 2008 at 02:13:09PM -0500, Josh Schmiedlin wrote:
> Hi there,
the message until something has occurred that requires a reply.  This concept is talked about in some of the IPC related
actual replying.
> Thanks,
> Josh
Your resource manager probably gets an unblock pulse when
this occurs.  If you're using the standard resource manager
framework in libc this will cause your
(resmgr_io_funcs_t *)->unblock() callout to be called which
should MsgError(rcvid, EINTR) to let the client go (after
any appropriate internal cleanup).
RE: Cancelling/slaying/killing reply blocked threads.
Thanks!!!
Sent: Wednesday, February 27, 2008 2:21 PM
To: general-community
Subject: Re: Cancelling/slaying/killing reply blocked threads.
> Hi there,
Resource Manager.  This ResMgr doesn't reply to the message until
about in some of the IPC related pages on this site.  As long as
however in the process of debugging and general implementation work I
like to Ctrl-C and/or slay my application that is sending the message.
MsgSend is still blocked on REPLY and i'm unable to fully kill the
ResMgr that does the actual replying.
> Thanks,
> Josh
General
http://community.qnx.com/sf/go/post5339
