Forum Topic - Regarding QNX 6.3.2 Header files: (2 Items)
I am new to QNX. I am trying to port an application on QNX 6.3.2. When I am trying to port I am facing with redefinition
 errors with system header files. For example,
In sys/time.h, we have a structure named timeval:
struct timeval {
        _CSTD time_t    tv_sec;         /* seconds */
    suseconds_t         tv_usec;        /* microseconds */
I have the same definition in my own application also like:
typedef struct timeval
    UINT4  tv_sec;   /* Time in Seconds */
    UINT4  tv_usec;  /* Time in Microseconds */
} timeval;
When I compile, I am facing with redefinition erros.
I am unable to suppress the inclusion of system header files when I compile from top level as other modules are also
requiring it.
I cross-checked the definition of timeval structure in Linux Header file: /usr/include/bits/time.h
# ifndef _STRUCT_TIMEVAL
#  define _STRUCT_TIMEVAL       1
#  include <bits/types.h>
/* A time value that is accurate to the nearest
   microsecond but also has a range of years.  */
struct timeval
    __time_t tv_sec;            /* Seconds.  */
    __suseconds_t tv_usec;      /* Microseconds.  */
# endif /* struct timeval */
#endif  /* need timeval */
In Linux, they have a flag to check for the redefinition of structure.(_STRUCT_TIMEVAL ).But in QNX I am unable to find
such a flag. Due to this,I am doing lots of patch work in my application.I am not sure how to avoid such kind of errors.
Please clarify me with a solution.Is there any better way to avoid it?
RE: Regarding QNX 6.3.2 Header files
Momentics refactoring feature could help you there.
-----Message d'origine-----
De : Nagarjuna b [mailto:community-noreply@qnx.com]
Envoyé : 8 août 2011 09:52
À : general-community
Objet : Regarding QNX 6.3.2 Header files
struct timeval {
    UINT4  tv_usec;  /* Time in Microseconds */ } timeval;
requiring it.
   microsecond but also has a range of years.  */ struct timeval
General
http://community.qnx.com/sf/go/post87893
