RE: automatic login, running of programs
02/12/2008 3:41 PM
post4973
Hi Joe,
If you want to have programs executed on system startup you can add them to
the /etc/rc.d/rc.local shell script. This is invoked fairly late in the
process. For example, that's where I start inetd.
If you want a shell instead of a login you can edit /etc/config/ttys and
replace /bin/login with /bin/sh. I've used this trick to start a high
priority shell on console 4, for example.
Hope this helps,
Keith Russell
Sent: February 12, 2008 15:31
To: general-community
Subject: automatic login, running of programs
I have been reading and trying to get my QNX Momentics machine to
automatically log into root and run programs (such as qconn) once it has
booted; I have been editing the /etc/system/sysinit file at the end,
changing the entry for /etc/rc.d/rc.sysinit (and also adding the file
/etc/system/config/nophoton and trying to load the login components
manually) and adding an entry for tinit to run the login command. I do not
need phlogin or any photon running, simply a console for now. Where can I
find a suitable snippet from sysinit that allows QNX Momentics to
automatically login and run a program through a console or shell (such as
qconn or any other program)?
Thank you very much for your help.
General
http://community.qnx.com/sf/go/post4971
