Forum Topic - _pulse question: (2 Items)
_pulse question
I have a question about the event structure _pulse. What is in the “zero” parameter of this structure, please?
If our system “locks-up” this appears to have garbage in it…
Example:
GOOD:
(gdb) bt full
#0  0x01069ed4 in MsgReceive () from …/third_party/QNX/qnx640/lib/hh/mx27/libc.so.3
#1  0x004ed0e4 in HalEventThread::EventThreadMain (this=0x6f6f78) at os/bsp/hh/mx27/src/lib/Hal/.objs/hh/mx27/../../../
halEventThread.cpp:305
        event = {type = 0, subtype = 0, code = 0 '\0', zero = "\020\000", value = {sival_int = 4, sival_ptr = 0x4},
scoid = 1073741832}
        rcvId = <value optimized out>
        __FUNCTION__ = "EventThreadMain"
BAD:
(gdb) bt full
#1  0x004ed0e4 in HalEventThread::EventThreadMain (this=0x6f5480) at os/bsp/hh/mx27/src/lib/Hal/.objs/hh/mx27/../../../
        event = {type = 0, subtype = 0, code = 0 '\0', zero = "îîî", value = {sival_int = 4, sival_ptr = 0x4}, scoid
= 1073741832}
Your web page seems to “skip” that description….
http://www.qnx.com/developers/docs/6.3.2/neutrino/lib_ref/p/_pulse.html
Thanks for any help with this.
RE: _pulse question
It's filler or space reserved for future use, which is why the documentation doesn't describe it. You can ignore the
contents of it (but if there's garbage there, you might have a problem with corrupted memory).
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
> From: Yvette Indovina [mailto:community-noreply@qnx.com]
> Sent: Tuesday, March 29, 2011 2:13 PM
> To: general-community
> Subject: _pulse question
> Example:
> GOOD:
> (gdb) bt full
> os/bsp/hh/mx27/src/lib/Hal/.objs/hh/mx27/../../../halEventThread.cpp:30
> 5
> "\020\000", value = {sival_int = 4, sival_ptr = 0x4}, scoid =
> 1073741832}
> BAD:
> (gdb) bt full
> 5
> value = {sival_int = 4, sival_ptr = 0x4}, scoid = 1073741832}
> http://community.qnx.com/sf/go/post84380
