Forum Topic - What should we infer from these messages from eide driver : (4 Items)
Hello All ,
We are getting these message from the eide driver when we are running our control  application which does and logging to
 the hardisk . We see this when we  run sloginfo
Jan 26 09:38:26    2    19     0 eide_reset:  complete 301 ms
Jan 26 09:38:26    2    19     0 eide_init_devices: WDC WD3000HLFS-01G6U0 path 0
, tid 1, udma -1, mdma -1, sdma -1, pio 4, mblk 16
Jan 26 09:38:38    2    19     0 eide_reset:  complete 301 ms
Jan 26 09:38:38    2    19     0 eide_init_devices: WDC WD3000HLFS-01G6U0 path 0
Jan 26 09:38:51    2    19     0 eide_reset:  complete 306 ms
Jan 26 09:38:51    2    19     0 eide_init_devices: WDC WD3000HLFS-01G6U0 path 0
Jan 26 09:39:00    2    19     0 eide_reset:  complete 301 ms
these messages repeat  almost ever 12 seconds ,  we are running on intel atmo processor .
Can any body tell me what the meaning of these messages, are and is it normal to see this messages or does it point to
any  potential problems .
Appreciate your help .
Thanks in advance
-subra
Re: What should we infer from these messages from eide driver
I have seen these on our systems too. It's been some time since then, but there were 2 occasions I remember.
- Running unicore kernel on multicore CPU ... switching to smp kernel solved the problem
- Running SATA ports in EIDE mode ... switching to AHCI mode and using devb-ahci solved the problem again
Regards, PKY
> Hello All ,
> control  application which does and logging to the hardisk . We see this when
> we  run sloginfo
>  0
>  0
>  0
> processor .
> to see this messages or does it point to any  potential problems .
> Thanks in advance
> -subra
Hello pavol ,
how do we switch to achci mode and start the dev-ahci driver , should that be part of the boot image or is there any
start up script file in which we can start the devb-ahci driver .
appreciate your reponse
-subra
Switching to AHCI mode could be probably done in your system BIOS.
In your boot file/script you should change devb-eide to devb-ahci. If you are using qnx supplied boot images for x86
platform, it should autodetect proper driver.
Regards, PKY
