Forum Topic - Trouble with STDIN not triggering select(). Works on Linux, not QNX:
In this project I am demuxing between STDIN and another socket. For some
reason hitting the enter key does not trigger select(). The QNX select()
man page mentions this:
[quote]
Caveats:
The select() function only works with raw file descriptors; it doesn't
work with file descriptors in edited mode. See the ICANON flag in the
description of the tcgetattr() function.
[/quote]
http://www.qnx.com/developers/docs/6.3.0SP3/neutrino/lib_ref/s/select.html
So my guess is that by default stdin is in edit mode. Is my assumption
correct? If so, can someone provide some code that would make select()
work for stdin?
Thank you!
Re: Trouble with STDIN not triggering select(). Works on Linux, not QNX
On Thu, Jan 24, 2008 at 03:12:01PM -0500, Zhenwang Yao wrote:
> [quote]
> Caveats:
> [/quote]
> work for stdin?
You shouldn't assume a default termios setting.  You should
always save what you inherit, set what you want, restore
what you inherited on exit.  See tcgetattr(), tcsetattr().
What manager is handling STDIN?
I'm the one having the select() issue. My friend made the first post while I was having some trouble with the QNX site.
I have determined that it is actually not an issue with STDIN (it does work). But rather select() is simply not trigger
the 2nd file descriptor for some reason. Please see
http://community.qnx.com/sf/discussion/do/listPosts/projects.community/discussion.community.topc1908
Thank you
