09/28/2010 12:57 PM
post68828
Hi Jesse,
Well, at least you can run in live mode. I will need some more information
to track this down.
When you have your system set up running from CD execute this command in a
terminal:
get-hw-info
This will store information about your system in
/tmp/hw-info-<hn>.txt
where <hn> is replaced with the hostname of your machine.
You will need to copy this file to another machine (e.g. via USB key or
network) so you can get it to me. The file is lengthy so it's easiest to
email it to me directly: keith@qnx.com. I'll post my response here, though.
Can you also include the output of 'fdisk /dev/hd0 show' both with and
without the partition?
You can try zeroing out the partition table with 'fdisk -z /dev/hd0'. There
may be some residual data left over from a previous partitioning.
Keith
On 10-09-27 19:17 , "Jesse Brockmann" <community-noreply@qnx.com> wrote:
> Keith,
> The motherboard is a Gigabyte GA-X58A-UD3R which uses a Intel X58 and ICH10R
> chipset.
> Fdisk shows the partition exactly like I would expect... I created a 10 GB
> partition and it looks fine.
> Interestingly, it seems running from a live boot also fails when I try to run
> mkqnx6fs /dev/hd0t179. It just hangs, the system becomes completely
> unresponsive.
> So, it seems to be able to create partitions but unable to format them.
> I deleted the partitions by just rerunning the installer, and deleting all
> existing partitions on machine using the installer. But, in live mode I can
> also delete the partitions.
> Regards,
> Jesse
>> Hi Jesse,
>> For future reference, this kind of question is usually best asked in the "QNX
>> Momentics Community Support" forum.
>> I haven't actually seen this issue before so I'll need to get some
>> information
>> fro you.
>> What hardware are you installing on? The IDE chipset would be useful to know.
>> After the failure could you run from the CD-ROM? I'd like to see the
>> partition
>> table
>> which you can get with 'fdisk /dev/hd0 show'?
>> When you said you deleted all of the partitions how did you do this?
>> Thanks,
>> Keith Russell
> http://community.qnx.com/sf/go/post68714
