We had met unable difficulty problem
09/01/2010 4:29 AM
post65384
We had met unable difficulty problem.
At now, every process were stoping at __i686.get_pc_thunk.cx () from /usr/qnx641/target/qnx6/x86/lib/libc.so.3
And we could not continue debugging procedure.
Backtrace log is following.
(gdb) file TickStub
Reading symbols from /root/pac/Unit/Source/private/HWJitterTest/TickStub...done.
(gdb) b main
Breakpoint 1 at 0x8049ccd: file main.c, line 644.
(gdb) run
Starting program: /root/pac/Unit/Source/private/HWJitterTest/TickStub
[New pid 741415 tid 1]
Program received signal 0, Signal 0.
0xb0319254 in __i686.get_pc_thunk.cx () from /usr/qnx641/target/qnx6/x86/lib/libc.so.3
(gdb) continue
Continuing.
(gdb) continue
Continuing.
(gdb) bt
#0 0xb0319254 in __i686.get_pc_thunk.cx ()
#1 0xb033ff15 in _dl_debug_state () at /home/builder/hudson/641/svn/lib/c/ldd/ldd.c:1001
#2 0xb0342f7d in ldd (frame=0x8047bc8)
at /home/builder/hudson/641/svn/lib/c/ldd/ldd.c:193
#3 0xb033f110 in _start_ () from /usr/qnx641/target/qnx6/x86/lib/libc.so.3
(gdb)
