Forum Topic - More another messages happen on gdb with attaching:: (2 Items)
We tried to use the attaching feature of debug how as following instructions.
Then the following error message happen as ‘Can't read symbols from /usr/qnx641/target/qnx6/x86/lib/libc.so.3: Memory
exhausted Error while reading shared library symbols:’
Please let me know regarding these massage.
# gdb pacrun
GNU gdb 6.8 qnx-nto update 5 (rev. 398)
Copyright (C) 2008 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>;
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "i386-pc-nto-qnx6.3.0"...
(gdb) attach 1572907
Attaching to program `/root/pac/Unit/Release/bin/pacrun', process 1572907
[New process 1572907]
Can't read symbols from /usr/qnx641/target/qnx6/x86/lib/libc.so.3: Memory exhausted
Can't read symbols from /usr/qnx641/target/qnx6/x86/usr/lib/libBSPlib.so: Memory exhausted
Can't read symbols from /usr/qnx641/target/qnx6/x86/usr/lib/libIOPDriver.so: Memory exhausted
Can't read symbols from /usr/qnx641/target/qnx6/x86/lib/libsocket.so.2: Memory exhausted
../../gdb/utils.c:904: internal-error: virtual memory exhausted: can't allocate 4072 bytes.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
Quit this debugging session? (y or n) n
Create a core file of GDB? (y or n) y
Can't read symbols from /usr/qnx641/target/qnx6/x86/usr/lib/libFgwXml.so: Memory exhausted
../../gdb/utils.c:904: internal-error: virtual memory exhausted: can't allocate 5248 bytes.
Can't read symbols from /usr/qnx641/target/qnx6/x86/usr/lib/libPC21Agent.so: Memory exhausted
Memory fault
Re: More another messages happen on gdb with attaching:
It looks like you are running out of memory. Gdb needs a lot of memory
for loading symbols.
Have you tried remote debugging? It uses a lot less memory on your
target, and provides a possibility of using IDE.
Let me know if you need help with remote debugging.
Thank you,
Aleksandar
