Trackers
Trackers
Forum Topic - May I ask question that enabling break points when debugging the IDE(momentics).: (2 Items)
Some how get connection between target and host-pc,
But next problems are happening,
It is could not stop several break-points , and log of operations are following.
Please let me know about counter measure of this issue.
Kengo Kinoshita
[MessageBox] as following lines
Launching HWJitterT QNX QCC has encountered a problem.
Attach to process 1663010 failed
Cannot access memory at address 0x2444c708
[Console Window] as following lines
207-gdb-set confirm off
207^done
(gdb)
208-gdb-set width 0
208^done
(gdb)
209-gdb-set height 0
209^done
(gdb)
210-interpreter-exec console echo
210^done
(gdb)
211-gdb-show prompt
211^done,value="(gdb) "
(gdb)
212-target-select qnx 192.168.70.2:8000
~"MsgNak received - resending\n"
~"Remote target is little-endian\n"
212^connected
(gdb)
213-gdb-set auto-solib-add off
213^done
(gdb)
214-gdb-set stop-on-solib-events 0
214^done
(gdb)
215 attach 1032229
&"attach 1032229\n"
attach 1032229
~"[New process 1032229 thread 1 (state = 0x03)]\n"
&"Cannot access memory at address 0x2444c708\n"
215^error,msg="Cannot access memory at address 0x2444c708"
(gdb)
216-gdb-exit
216^exit
Re: May I ask question that enabling break points when debugging the IDE(momentics).
This error usually indicate mismatch between binaries/libraries on host and target. Do you have same version of QNX on
host and target?
Do you have same version of your binary on host and target?
> Regards,
> Kengo Kinoshita
> 207^done
> (gdb)
> 208-gdb-set width 0
> 208^done
> (gdb)
> 209^done
> (gdb)
> 210^done
> (gdb)
> 211-gdb-show prompt
> (gdb)
> 212^connected
> (gdb)
> 213^done
> (gdb)
> 214^done
> (gdb)
> 215 attach 1032229
> &"attach 1032229\n"
> attach 1032229
> (gdb)
> 216-gdb-exit
> 216^exit
> http://community.qnx.com/sf/go/post63364
