Forum Topic - May I ask few questions regarding How to debug on IDE(momentics): (3 Items)
I already read USES’ GUID of IDE, and following those operations sequences.
And some how reached to build and pre-debug-procedure,
Now standing a wall of trouble that starting debug procedure.
And I attaching several setting of windows as following.
So, I thinking and searching the way that step into debug.
Our testing environment as follows.
Host-pc          installed momentics on windows-xp
Target machine   installed qnx 6.4.0 and inetd and qconn are running
I really have going to know what cause of un-visible ‘DEBUG-button’,
please see Figure1
Please let me know the cause of the above problems.
Regards.
Kengo KInoshita
Attachment: Text ErrorReport.doc 195 KB
Re: May I ask few questions regarding How to debug on IDE(momentics)
1st picture show that target is not connected.
Check
a) qconn is running on target
b) you can ping your target from your host
c) you host does not have outbound firewall
d) try to telnet from you host from command line to a port 8000 (if cannot - no connectivity)
> please see Figure1
> Regards.
> Kengo KInoshita
> http://community.qnx.com/sf/go/post63223
Also, you are using the Run Configuration dialog as opposed to the Debug Configuration dialog. You need to use Debug
Configuration if you plan on debugging.
The Debug Configuration dialog is available via the Run menu on the main window (same place you would have launched the
Run Configuration dialog). It can also be found under the icon of the green bug on the toolbar, or via the Debug As menu
 on your binary.
> Check
> no connectivity)
> > please see Figure1
> > Regards.
> > Kengo KInoshita
> > General
