Forum Topic - May I ask how to write a interrupt handlers.: (2 Items)
Dear  Eric and Boudreau:
Now I wrote the following codes.
But did not work interrupt sequence regarding isr_handler1 and isr_handler2.
It is not use signal and event only use return value of ISR(interrupt service routine).
Please teach me where points of existing bugs.
Kengo Kinoshita
#include <sys/siginfo.h>
const struct sigevent *isr_handler1( void *arg, int id)
 InterruptMask(  TIM0  , id);
 event_.sigev_code  = _TM0;
 return( &event_);
// procmgr_event_notify()
const struct sigevent *isr_handler2( void *arg, int id)
 InterruptMask(TIM0-1 , id);
 event_.sigev_code  = _TM1;
 return( &event_);
main()
       pthread_attr_t attr;
        int breakFlg;
         pthread_attr_init( &attr );
        SIGEV_INTR_INIT (&event_);
        memset( ¶m, 0x0, sizeof(param) );
        memset( &idle_param, 0x0, sizeof(idle_param) );
       interruptID1 = InterruptAttach     (
                        TIM0,
                        isr_handler1,
                        NULL,
                        0,
                        0);
        interruptID2 =   InterruptAttach     (
                         TIM0-1,
                        isr_handler2,
                        NULL,
                        0,
                        0);
       for(i=0;i<evaluateCycle;){
           while(1){
                printf( "Wait interrupt\n");
                InterruptWait(NULL, NULL);
                printf( “Exit interrupt\n");
                switch( event_.sigev_code ){
                        case _TM1:
//                                    breakFlg=1;
                                      event_.sigev_code=0;
                                      InterruptUnmask(irq+ InterruptT0-1, interruptID2 );
                               break;
                       case _TM0:
                                     breakFlg=1;
ptT0     , interruptID1 );
                               break;
                if (breakFlg==1) {
                    breakFlg=0;
                    break;
RE: May I ask how to write a interrupt handlers.
You need to obtain I/O privileges before you call InterruptAttach():
  ThreadCtl( _NTO_TCTL_IO, 0 );
You should also check return codes to make sure everything is working.
For more information, see the Writing an Interrupt Handler chapter in
the Neutrino Programmer's Guide:
http://www.qnx.com/developers/docs/6.5.0/topic/com.qnx.doc.neutrino_prog
/inthandler.html
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
> From: Kengo Kinoshita [mailto:community-noreply@qnx.com]
> Sent: Tuesday, August 17, 2010 9:00 AM
> To: general-community
> Subject: May I ask how to write a interrupt handlers.
> and isr_handler2.
> Regards,
> Kengo Kinoshita
>  return( &event_);
>  return( &event_);
> main()
>         int breakFlg;
>                         TIM0,
>                         isr_handler1,
>                         NULL,
>                         0,
>                         0);
>                          TIM0-1,
>                         isr_handler2,
>                         NULL,
>                         0,
>                         0);
>            while(1){
>                 printf( "Exit interrupt\n");
>                         case _TM1:
> //                                    breakFlg=1;
>                                break;
>                        case _TM0:
>                                      breakFlg=1;
