Forum Topic - RE: Thank you for your support.:
Dear  Boudreau:
We try to confirm early morning.
And would inform result to you.
Kengo Kinoshita.
By the way,
We have next challenging task that as using IDE(momentics).
And We have Makefile and several c
sourcefiles and header files at the starting time.
How we take first step from shell environment to IDE environment.
Please let us know how about starting direction of IDE development.
----- Original Message -----
>There's no cdefs.h in the archive I sent.  You should use the
>shipped, qnx one.  Just untar on a qnx system, don't add
>any extra bsd files and do a make.
>Regards,
>-seanb
>-----Original Message-----
>From: Kengo Kinoshita [mailto:community-noreply@qnx.com]
>Sent: Thu 8/5/2010 6:08 AM
>To: general-community
>Subject: Thank you for your support.
>Dear  Boudreau:
>Thank you for your support,
>But sadly when a lot of errors happen.
>Please teach me how to solve them.
>Regards,
>Kengo Kinoshita
># # cd x86
># # make
># make -j 1 -Co -fMakefile
>make: Entering directory `/root/dd/x86/o'
>/usr/qnx640/host/qnx6/x86/usr/bin/qcc -Vgcc_ntox86 -c -Wc,-Wall -Wc,-Wno-parentheses  -O -DNDEBUG   -I. -I/root/dd/x86/
o -I/root/dd/x86 -I/root/dd -I/usr/qnx640/target/qnx6/usr/include     -DBUILDENV_qss  /root/dd/conv.c
>In file included from /root/dd/extern.h:38,
>                 from /root/dd/conv.c:55:
>/root/dd/cdefs.h:19:27: error: machine/cdefs.h: No such file or directory
>/root/dd/cdefs.h:21:27: error: sys/cdefs_elf.h: No such file or directory
>/root/dd/cdefs.h:26:1: warning: "__BEGIN_DECLS" redefined
>In file included from /root/dd/conv.c:36:
>/usr/qnx640/target/qnx6/usr/include/sys/cdefs.h:124:1: warning: this is the location of the previous definition
>/root/dd/cdefs.h:27:1: warning: "__END_DECLS" redefined
>/usr/qnx640/target/qnx6/usr/include/sys/cdefs.h:127:1: warning: this is the location of the previous definition
>In file included from /root/dd/conv.c:55:
>/root/dd/extern.h:53: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'bwrite'
>/root/dd/extern.h:60: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'ddflags'
>/root/dd/extern.h:61: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'files_cnt'
>/root/dd/extern.h:63: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
>/root/dd/extern.h:64: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'a2e_32V'
>/root/dd/extern.h:65: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'e2a_32V'
>/root/dd/extern.h:66: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'a2ibm_32V'
>/root/dd/extern.h:67: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'casetab'
>/root/dd/conv.c: In function 'def':
>/root/dd/conv.c:70: error: 'u_char' undeclared (first use in this function)
>/root/dd/conv.c:70: error: (Each undeclared identifier is reported only once
>/root/dd/conv.c:70: error: for each function it appears in.)
>/root/dd/conv.c:70: error: 'inp' undeclared (first use in this function)
>/root/dd/conv.c:71: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
>/root/dd/conv.c:71: error: 't' undeclared (first use in this function)
>/root/dd/conv.c:73: error: 'ctab' undeclared (first use in this function)
>/root/dd/conv.c: In function 'block':
>/root/dd/conv.c:127: error: 'u_char' undeclared (first use in this function)
>/root/dd/conv.c:127: error: 'inp' undeclared (first use in this function)
>/root/dd/conv.c:127: error: 'outp'...
Re: Thank you for your support.
Please read the IDE documentation. Including Ten First Steps guide:
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=/com.qnx.doc.momentics_quickstart/about.html
If you have questions after that let us know
> By the way,
