Forum Topic - Thank you for your support.:
Dear  Boudreau:
Thank you for your support,
But sadly when a lot of errors happen.
Please teach me how to solve them.
Kengo Kinoshita
# # cd x86
# # make
# make -j 1 -Co -fMakefile
make: Entering directory `/root/dd/x86/o'
/usr/qnx640/host/qnx6/x86/usr/bin/qcc -Vgcc_ntox86 -c -Wc,-Wall -Wc,-Wno-parentheses  -O -DNDEBUG   -I. -I/root/dd/x86/o
 -I/root/dd/x86 -I/root/dd -I/usr/qnx640/target/qnx6/usr/include     -DBUILDENV_qss  /root/dd/conv.c
In file included from /root/dd/extern.h:38,
                 from /root/dd/conv.c:55:
/root/dd/cdefs.h:19:27: error: machine/cdefs.h: No such file or directory
/root/dd/cdefs.h:21:27: error: sys/cdefs_elf.h: No such file or directory
/root/dd/cdefs.h:26:1: warning: "__BEGIN_DECLS" redefined
In file included from /root/dd/conv.c:36:
/usr/qnx640/target/qnx6/usr/include/sys/cdefs.h:124:1: warning: this is the location of the previous definition
/root/dd/cdefs.h:27:1: warning: "__END_DECLS" redefined
/usr/qnx640/target/qnx6/usr/include/sys/cdefs.h:127:1: warning: this is the location of the previous definition
In file included from /root/dd/conv.c:55:
/root/dd/extern.h:53: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'bwrite'
/root/dd/extern.h:60: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'ddflags'
/root/dd/extern.h:61: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'files_cnt'
/root/dd/extern.h:63: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/root/dd/extern.h:64: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'a2e_32V'
/root/dd/extern.h:65: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'e2a_32V'
/root/dd/extern.h:66: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'a2ibm_32V'
/root/dd/extern.h:67: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'casetab'
/root/dd/conv.c: In function 'def':
/root/dd/conv.c:70: error: 'u_char' undeclared (first use in this function)
/root/dd/conv.c:70: error: (Each undeclared identifier is reported only once
/root/dd/conv.c:70: error: for each function it appears in.)
/root/dd/conv.c:70: error: 'inp' undeclared (first use in this function)
/root/dd/conv.c:71: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/root/dd/conv.c:71: error: 't' undeclared (first use in this function)
/root/dd/conv.c:73: error: 'ctab' undeclared (first use in this function)
/root/dd/conv.c: In function 'block':
/root/dd/conv.c:127: error: 'u_char' undeclared (first use in this function)
/root/dd/conv.c:127: error: 'inp' undeclared (first use in this function)
/root/dd/conv.c:127: error: 'outp' undeclared (first use in this function)
/root/dd/conv.c:127: warning: left-hand operand of comma expression has no effect
/root/dd/conv.c:128: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/root/dd/conv.c:128: error: 't' undeclared (first use in this function)
/root/dd/conv.c:137: warning: left-hand operand of comma expression has no effect
/root/dd/conv.c:137: warning: value computed is not used
/root/dd/conv.c:154: warning: left-hand operand of comma expression has no effect
/root/dd/conv.c:156: error: 'ctab' undeclared (first use in this function)
/root/dd/conv.c: In function 'block_close':
/root/dd/conv.c:222: error: 'ctab' undeclared (first use in this function)
/root/dd/conv.c: In function 'unblock':
/root/dd/conv.c:238: error: 'u_char' undeclared (first use in this function)
/root/dd/conv.c:238: error: 'inp' undeclared (first use in this function)
/root/dd/conv.c:239: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/root/dd/conv.c:239: error: 't' undeclared (first use in this function)
/root/dd/conv.c:242: error: 'ctab' undeclared (first use in this...
RE: Thank you for your support.
There's no cdefs.h in the archive I sent.  You should use the
shipped, qnx one.  Just untar on a qnx system, don't add
any extra bsd files and do a make.
From: Kengo Kinoshita [mailto:community-noreply@qnx.com]
Sent: Thu 8/5/2010 6:08 AM
To: general-community
Subject: Thank you for your support.
Dear  Boudreau:
Kengo Kinoshita
# # cd x86
# # make
/root/dd/conv.c:238: error: 'u_char'...
Attachment: Text winmail.dat 4.91 KB
More once question happen
More once question happen,
Currently, We create shell batch that as 'makes.sh'.
And executed result as attached 'makes.result.txt'
In result of make,
Stdlib was not linked that result message informed caution.
Please let us know solve operation of it.
Regards.
Kengo Kinoshita.
Attachment: Text makes.result.txt 693 bytes Text makes.sh 473 bytes
RE: More once question happen
setprogname() is in libnbutil.  See the common.mk in the
archive I posted.  It's probably easier to just use make
and the makefiles in that archive.
Sent: Thu 8/5/2010 7:26 PM
Subject: More once question happen
In result of make,
Regards.
Kengo Kinoshita.
General
http://community.qnx.com/sf/go/post61930
Attachment: Text winmail.dat 2.66 KB
