Trackers
Trackers
Forum Topic - raw ethernet packets: (5 Items)
How can I send a plain (raw) ethernet packet under QNX? Since want to send packets with a small payload at a high
frequency, using IP/UDP would lead to a unacceptably high overhead.
Under LINUX this can be done using
 s = socket(AF_PACKET, SOCK_RAW, htons(ETH_P_ALL));
Since there seems to be no AF_PACKET under QNX, so this obviously doesn't work.
I couldn't find anything in the documentation except:
" SOCK_RAW -- provides access to internal network protocols and interfaces. Available only to the superuser, this type
isn't described here."
Is it described anywhere else in the documentation? I would be thankful for any hint as to how this can be done under
QNX.
Thomas
Re: raw ethernet packets
> send packets with a small payload at a high frequency, using IP/UDP
> doesn't work.
> interfaces. Available only to the superuser, this type isn't described
> here."
> for any hint as to how this can be done under QNX.
In io-pkt this can be done with bpf / libpcap.
In io-net the closest thing we had was nfm-nraw.so
which allowed one to open() / read() / write() on
/dev/io-net/enX.  nraw wasn't shipped AFAIK.
Thanks for the reply.
As you suggest, I cannot find nfm-nraw.so on my system, so it apparently
wasn't shipped.
There is a nfm-bpf.so, but use nfm-bpf.so suggests raw IP (not raw
Ethernet) only.
Is it correct that io-pkt.so is from the next generation protocol stack,
which means it currently isn't possible to send raw Ethernet under QNX?
That is, the only possibility would be to use the Network DDK to attach
to io-net?
Thomas
> > doesn't work.
> > here."
> -seanb
> http://community.qnx.com/sf/go/post2748
Dipl.-Ing. Thomas Buschmann
Technische Universitaet Muenchen
Lehrstuhl fuer Angewandte Mechanik
Boltzmannstrasse 15, D-85747 Garching
Phone: +49 89/289-15228
Fax  : +49 89/289-15213
eMail: buschmann@amm.mw.tum.de
WWW  : http://www.amm.mw.tum.de/People/buschmann.html
> wasn't shipped.
> Ethernet) only.
> to io-net?
> Thomas
In io-net bpf was read only.  So yes, for io-net the options
are roll your own via the tdk or get a hold of nfm-nraw
(sales rep?).
Thanks!
> > wasn't shipped.
> > Ethernet) only.
> > to io-net?
> > Thomas
> (sales rep?).
> -seanb
> http://community.qnx.com/sf/go/post2755
