Forum Topic - RE: QNX porting on Devkit 8000: (1 Item)
We are trying to port QNX on Devkit 800 Board.
Is there any BSP available / under development for DevKit8000 Board.
Currently we using Beagle boards BSP to port on Devkit Board.
Devkit board is booting up but giving error for USB as
DLL Error Library cannot be found
 FAILED  - io_usb_dlopen
unable to load dll devu-omap3530
Plz give your ideas to fix the above problem.
Thanks in advance.
Thanks & Regards,
     Nilesh
This Email may contain confidential or privileged information for the intended recipient (s) If you are not the intended
 recipient, please do not use or disseminate the information, notify the sender and delete it from your system.
______________________________________________________________________
