Forum Topic - QNX CAN dirvers??: (4 Items)
QNX CAN dirvers??
Where are the specifications for a "QNX compatible CAN driver" available? E.g. what standard APIs to be supported etc?
Being new to this domain, any help, guidance, support will be welcome.
Gog.
Re: QNX CAN dirvers??
Gopal Gorur wrote:
What means "QNX compatible CAN driver" ?   You are talking about the CAN
API ?
IMHO, what you need is a CAN driver which follows the concept of the
QNX  resource managers.
Its API should cover optimized all aspects of the individual CAN
controller ...
There is not a standard CAN controller ... how can we have a standard API ??
--Armin
http://www.steinhoff-automation.com/can.htm
Hi Armin,
After some research in the mean time, I have concluded that, to have a "QNX compatible CAN driver" it means to have the
following supported for the CAN controller:
read()
write()
ioctl()
poll()
select()
open()
close()
Also to somehow use the following prototypes:
InterruptAttachEvent()
InterruptAttach()
Anyways, this is only my assumption.
I agree that there is no standard CAN controller (thank god!) but most of them adhere to Bosch CAN 2.0B specs. But I
think with the above APIs supported, such a CAN driver can be ported onto any system that has QNX running on it, some
apps, and has a CAN controller that needs a driver.
Does this make sense to you now?
Gog.
Gopal Gorur wrote:
> Hi Armin,
the following supported for the CAN controller:
> read()
> write()
These calls are not appropriate to the needs of CAN communication.
We use CanSend and CanReceive as optimized read/write calls based on
devctrl calls.
> ioctl()
devctrl ...
> poll()
non blocking CanRead ..
> select()
receive blocking on a driver pulse ... select() is too slow.
> open()
> close()
OK
> InterruptAttach()
InterruptAttach is the way to go ... at least if you have to handle
shared PCI interrupts.
There are lot of other call necessary ... setting of filters,
configuration actions, reading of status informations, e.g. for the
Intel chip sending remote frames, different controller registers a.s.o.
 But these calls are depending on the controller type.
If a controller isn't compliant to the CAN 2.0B ISO standard ... it
would'nt be CAN controller.
>  But I think with the above APIs supported, such a CAN driver can be ported onto any system that has QNX running on it
, some apps, and has a CAN controller that needs a driver.
The driver  dependeds on the CAN controller and the hardware interfaces
... the API depends on the functionality of the CAN controller.
With your API "definition" you would loose a lot of the functionallity
of the individual CAN controllers ...
Regards
--Armin
