Forum Topic - get name widget in action : (2 Items)
Hi I have widgets: PtText1,PtText2,PtText3 ... and i want use the same function on each widgets. The function must get
name widget for example PtText1 split this String and return only numer in this case "1". And get value from PtText1(for
 example "0") and set this value in variable like this pgmData[1] = 0;
int
myfunction(PtWidget_t *widget, ApInfo_t *apinfo, PtCallbackInfo_t *cbinfo)
PtSetArg(&arg[0],Pt_ARG_TEXT_STRING,&textp,0);
PtGetResources(ABW_PtText1,1,arg);
pgmData[???] = ???
widget = widget,apinfo = apinfo,cbingo = cbinfo;
return(Pt_CONTINUE);
Re: get name widget in action
Take a look at  ApInstanceName() ; it will return the widget instance's name you provided to PhAB.
Though this will work (if you instruct PhAB to store the instance names), I personally prefer using the Pt_ARG_USER_DATA
 instead of the instane name in such cases.
- Thomas
