Forum Topic - QNX 6.1.1 vs. Real-Time Linux: (4 Items)
Any strategy against Real-Time Linux ??
Real-time Linux comes e.g. as boot option with openSUsE 11.1 and has the following features:
 - fully pre-emptive single kernel with 99 real-time priorities
 - interrupt latency in the range of 12us  (IRQ->ISR->IR-thread)
 - SMP support
 - multi-core support (CPU shield e.g)
 - extrem fast message passing by
                -- TIPC  for cluster operation
                -- LINX for non cluster operation (ENEA/OSE)
 - Ethernet based fieldbus implementations: EtherCAT, Powerlink, Sercos III, Ethernet/IP a.s.o
 - high resolution timing for all timing services (non polling timer services)
 - no problems with context switches in the range of 200us under heavy load
 - huge offering of graphical interfaces (hardware/software)
 - performance of the unaccelerated video interface 4 times better than the performance of Photon
 - huge offering of applications
 - the end user doesn't have to fiddle around with a "real-time kit" ... just boot into real-time
Any ideas ??
--Armin
Re: QNX 6.4.1 vs. Real-Time Linux
> following features:
>  - SMP support
> Ethernet/IP a.s.o
> boot into real-time
> Any ideas ??
> --Armin
Re: QNX 6.1.1 vs. Real-Time Linux
No kernel can be *fully* pre-emptive. When it needs to fiddle around with the MMU, it cannot be pre-empted. The question
 is, how much latency it can mean in Linux. Surely more than in QNX...
> ...with 99 real-time priorities
We have 255! We are better, yieppie! ;-)
On which hardware? A fast x86? I believe QNX is many times faster...
>  - SMP support
QNX has it for 10 years...
What's CPU shield?
Yeah that's something QNX should have, too. I guess they are using some extra timer that today's hardware is providing..
Most of them are GPL-contaminated. Once you link with it, you are obliged to open-source your code.
How did you measure it? What was the graphics driver on the QNX side? The software-only rendering surely isn't very fast
. Also remember, that QNX is compiled to be compatible even with 486's. No use of MMX, etc.
Most are in pkgsrc, for QNX, aswell.
> boot into real-time
Just boot into real-time? Not understanding what all those processes that are started there really do? That means having
 no control and no idea what is going on when something doesn't behave as it should...
All the so-called Real Time Linux solutions look nice on paper but as soon as you try to do something with them, you
begin to hate'em... ;-) (says the QNX guy ;-))
Also, we have the better tools, the better OS architecture, and better Services! And we protect the IP of the customer..
- Malte
Just a reality check :)
> MMU, it cannot be pre-empted. The question is, how much latency it can mean in
Why should it be  more? The kernel isn't split into process manager and micro kernel.
> On which hardware?
Dual-core, 1.8GHz
Seems not to be the case. For instance the non real-time 2.6.31 kernel is able to handle 1000 CAN frames/sec without
loosing a single frame.
> >  - SMP support
Linux has SMP since 14 years :)
> What's CPU shield?
e.g http://www.cyberciti.biz/tips/setting-processor-affinity-certain-task-or-process.html
> services)
> timer that today's hardware is providing...
Yes, its's available for Linux since years!
 It's part of the POSIX 1003.1b Section 14 (Clocks and Timers) API.
That's not the case at user level ... GPL contamination is possible at driver level, but there is the UIO interface.
> software-only rendering surely isn't very fast. Also remember, that QNX is
Most are X11 based ... that means not very useful.
> just
> > boot into real-time
> started there really do? That means having no control and no idea what is
Booting into real-time is just a boot option with e.g. SUSE 11.1
> you try to do something with them, you begin to hate'em... ;-) (says the QNX
> guy ;-))
Yes, I dislike the dual-kernel approach. The PREEMPT_RT version (single kernel) is perfect :)
You should check it out !
Eclipse and a lot of other tools are available for LINUX.
what is better or not better depends on the requirements.
The service would be better if QSS would care about version conflicts between releases.
A run-time kit was available for QNX 6.3.2 ... has been dropped for 6.4 ... and will be available again for 6.5? That's
some kind o Zick-Zack service :)
>And we protect the IP of the customer...
Yes, that's very easy :)
--Armin
