Forum Topic - Oflline memory analysis:
The Target board we are using does not have Ethernet OR JTAG. Only interface available is serial.
Is it possible to get Offline memory analysis ? Like tracelogger? Then import the file to IDE for analysis
Request help
AW: Oflline memory analysis
prerequisite is that you can store tracing data on your target and transfer this data later to your host pc.
If this is possible you can do all the analysis like System Profiling, Application Profiling or Memory Analysis.
-use tracelogger on your target to record kernel traces
-use any instrumented binary to record data usable for Application Profiling, contolled through env vars
-and some for Memory Profiling
in the IDE manual you'll not only find the "online" versions but also the hints
you neede to use cmd line interface to record data and how to import them to IDE
http://www.qnx.com/developers/docs/6.4.0/ide_en/user_guide/about.html
http://www.qnx.com/developers/docs/6.4.1/ide_en/user_guide/about.html
HTH
/hp
>Von: nkr krishnan [mailto:community-noreply@qnx.com]
>Gesendet: Mittwoch, 30. September 2009 13:31
>An: general-community
>Betreff: Oflline memory analysis
>Request help
>General
>http://community.qnx.com/sf/go/post39050
Re: AW: Oflline memory analysis
We are using QNX 6.3.2 version. Tried using
LD_PRELOAD=/tmp/libmalloc_g.so MALLOC_TRACE=/tmp/log.memory
 MALLOC_CTHREAD=1 ./my_app
as in the 6.4.0 manual. Did not get any log in the tmp directory.
Also tried with -pg option. Not sure why we did not get any log for application as well.
Am i missing something?
Request your help,
nkr
AW: AW: Oflline memory analysis
just to be sure: you're linking against shared libc?
you can check whether malloc_g is loaded? using env var DL_DEBUG=1
>Gesendet: Mittwoch, 30. September 2009 15:28
>Betreff: Re: AW: Oflline memory analysis
>Request your help,
>Thanks,
>nkr
>General
>http://community.qnx.com/sf/go/post39067
What is the purpose of your analysis? Finding memory allocations? Memory leaks? or memory errors? You have to specify
more options (env vars) depends on what are looking for
We wanted to analyze memory allocation, errors, heap for a program.
nkr
In 6.4.0 and up it is something like this
LD_PRELOAD=librcheck.so MALLOC_TRACE=/tmp/output.rmat MALLOC_CKALLOC=1
./your_app
It would create a file /tmp/output.rmat which can be imported to MAT
tool in IDE.
Try simple case first:
main(){
   malloc(7);
Does it work?
> Thanks,
> nkr
> http://community.qnx.com/sf/go/post39345
