| wiki5385: QEMUAsAnOMAP3530BeagleboardTarget | ||
Prerequisites#
IFS#To build the IFS, simply type make at the top level directory of the unzipped BSP archive. PMIC Problem#There is currently a problem with the IFS's PMIC driver on the emulated Beagle board. To disable the PMIC driver, comment the relevant lines in $BSP_DIR/src/hardware/startup/boards/omap3530/beagle.build:
#display_msg Configure power management chip
#pmic_tw4030_cfg
#display_msg Starting USB EHCI Host and OTG host driver...
#io-usb -dehci-omap3 ioport=0x48064800,irq=77 -domap3530-mg ioport=0x480ab000,irq=92
#waitfor /dev/io-usb/io-usb 4
NAND Drive#The board will be booting and running off an emulated 256 MB NAND drive. This drive is composed of 2K pages, each followed by a 64 byte checksum value. It is thus insufficient to create a zeroed 256 MB file to use as an emulated file. The attached archive contains a script, mknand.sh, that creates the drive file and loads the different components (X-loader, U-boot, IFS) onto it. Whenever the drive file is modified, a checksum calculator should be executed to fix the checksum values. The calculator's source code is included in the archive as nand_ecc.c. When mknand.sh is first executed, it will create the NAND drive file and load X-loader and U-boot into their appropriate locations. The script should also be given the path to the IFS image, which, if loaded from the BSP, is $BSP_DIR/images/ifs-omap350-beagle.bin. Subsequently, any change to the IFS requires mknand.sh to be invoked again in order to update the drive, followed by ecc_nand to compute the new checksum. The mknand.sh script is invoked with the following command line: $ ./mknand.sh DRIVE_FILE IFS_PATH Where DRIVE_FILE is a name for the NAND image and IFS_PATH is the full path to the QNX Beagle IFS file. The checksum calculator should be executed as follows: $ ./nand_ecc DRIVE_FILE 0x0 0xe80000 Where DRIVE_FILE is the file created by mknand.sh. Makefile#A Makefile included in the archive automates the steps above. Simply set the top-level directories as required, and type "make" to create the drive. Running QEMU#QEMU should be executed as follows: $ qemu-system-arm -M beagle -m 256 -mtdblock DRIVE_FILE -nographic Where DRIVE_FILE is the file created by mknand.sh. To emulate a serial connection to the board, append -serial pty to the command line (other serial emulators are available, such as a TCP socket). Booting QNX#By default, the image displays the U-boot menu. You need to manually stop the boot process (press any key), and use the following command to boot QNX: $ nand read 0x80100000 0x280000 0x400000; go 0x80100000 This boot command can be written into the NAND drive and executed automatically on subsequent boots: $ setenv bootcmd 'nand read 0x80100000 0x280000 0x400000; go 0x80100000' $ saveenv Kernel Debugger#Building#To use the kernel debugger, apply the following changes to the beagle.build file:
startup-omap3530 -L 0x87E00000,0x200000 -v -D8250.0x49020000^2.9600.48000000.16 beagle
gdb_kdebug -D0 -v -K
[+keeplinked uid=0 gid=0 perms=0700] PATH=:/proc/boot:/sbin:/bin:/usr/sbin:/usr/bin LD_LIBRARY_PATH=:/proc/boot:/lib:/usr/lib:/lib/dll procnto-instr -v
Debugging#Run QEMU with a serial emulator (such as PTY). If you are using a serial terminal, such as minicom, it must be disconnected before the debugger is attached. Run GDB with the following command-line: $ ntoarm-gdb SYM_FILE Where SYM_FILE is the file created by the keeplinked directive, in the image directory ($BFS_DIR/images). Then issue the GDB commands: (gdb) set remotebaud 9600 (gdb) target remote DEVICE Where DEVICE is the serial device connected to with QEMU's -serial option. If using a PTY, QEMU will report the device path (e.g., /dev/pts/5) when it starts.
