| wiki3951: TiAm3517EvmNto641ReleaseNotes (Version 9) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Release Notes for the QNX Neutrino 6.4.1 BSP for Texas Instruments AM3517 EVM Board#System requirements#Target system#
Host development system#
The interrupt vector table can be found in the buildfile located at src/hardware/startup/boards/am3517evm/build Getting Started#Step 1: Connect your hardware#
Step 2: Build the BSP#You can build a BSP OS image from the source code or the binary components contained in a BSP package. For instructions about building a BSP OS image, please refer to the chapter Working with a BSP in the Building Embedded Systems manual.Step 3: Transfer the OS image to the target using the ROM monitor#On your host machine, start your favorite terminal program with these settings:
Setting up the environment#Apply power to the target board. You should see output on your terminal console, similar to the following: Texas Instruments X-Loader 1.42 Starting X-loader on MMC Reading boot sector 213268 Bytes Read from MMC Starting OS Bootloader from MMC... Starting OS Bootloader... U-Boot 2009.08 (Dec 08 2009 - 23:00:10) AM35xx-GP ES1.0, L3-165MHz am3517evm board + LPDDR/NAND I2C: ready DRAM: 256 MB NAND: 512 MiB In: serial Out: serial Err: serial I2C read: I/O error HECC U20: port before = 000000FF I2C read: I/O error I2C read: I/O error HECC U20: programmed CAN_STB low I2C read: I/O error HECC U20: port after = 000000FF Die ID #40a600000000000001543b210601a01b Net: davinci_emac_initialize Ethernet PHY: GENERIC @ 0x00 DaVinci EMAC Hit any key to stop autoboot: 0 TFTP download#This method requires a raw image, which is simply a binary image, with a header on the beginning, that allows the bootloader to jump to the very beginning of the image (the raw header), where it executes another jump to the first instruction of the image. Next, use the saveenv command to configure the following parameters: serverip gatewayip netmask bootfile ipaddr ethaddr Once these parameters are configured, use the saveenv command to store your changes. Refer to the U-Boot documentation for more information. After U-boot is configured, boot the ifs-am3517evm.raw image as follows (we'll assume it's in a directory called /xfer/) from the AM3517EVM # prompt: tftpboot 0x80100000 /xfer/ifs-am3517evm.raw At this point you should see the ROM monitor download the OS image, indicated by a series of number signs. You'll also see output similar to this when it completes downloading:
TFTP from server 10.42.104.16; our IP address is 10.42.104.17
Filename '/root/ifs-am3517.raw'.
Load address: 0x80100000
done
Bytes transferred = 2355312 (23f070 hex)
AM3517EVM #
go 0x80100000 You should see output similar to the following, with the QNX Neutrino welcome message on your terminal screen: ## Starting application at 0x80100000 ... CPU0: L1 Icache: 256x64 CPU0: L1 Dcache: 256x64 WB CPU0: L2 Dcache: 4096x64 WB CPU0: VFP 410330c1 CPU0: 411fc087: Cortex A8 rev 7 500MHz System page at phys:80011000 user:fc404000 kern:fc404000 Starting next program at vfe043df0 cpu_startnext: cpu0 -> fe043df0 coproc_attach(10): replacing fe065044 with fe064928 coproc_attach(11): replacing fe065044 with fe064928 Welcome to QNX Neutrino 6.4.1 on the Texas Instruments AM3517 EVM (ARMv7 Cortex-A8 core) SD card download#Copy the raw OS image ifs-am3517evm.raw into a mmcsd card, then insert the SD card in J14 MMCSD port and apply power to the target board. After U-boot is started, boot the ifs-am3517evm.raw image in the mmcsd card as follows from the AM3517EVM # prompt: mmcinit fatload mmc 0 0x80100000 ifs-am3517evm.raw go 80100000 At this point you should see the ROM monitor download the boot image, indicated by a series of number signs. You'll also see output similar to this when it completes downloading: reading ifs-am3517evm.raw 1536276 bytes read ## Starting application at 0x80100000 ... CPU0: L1 Icache: 256x64 CPU0: L1 Dcache: 256x64 WB CPU0: L2 Dcache: 4096x64 WB CPU0: VFP 410330c1 CPU0: 411fc087: Cortex A8 rev 7 500MHz System page at phys:80011000 user:fc404000 kern:fc404000 Starting next program at vfe043df0 cpu_startnext: cpu0 -> fe043df0 coproc_attach(10): replacing fe065044 with fe064928 coproc_attach(11): replacing fe065044 with fe064928 Welcome to QNX Neutrino 6.4.1 on the Texas Instruments AM3517 EVM (ARMv7 Cortex-A8 core) Now you can test the OS, simply by executing any shell builtin command or any command residing within the OS image (e.g. ls). Flashing the IPL on to the target#Step A: Create the IPL image#Run the mkflashimage script, inside the /images directory of the BSP. The output file from this script is a binary IPL image called ipl-am3517evm.bin and nand-ipl-am3517evm.bin. The ipl-am3517evm.bin file is used to place a temporary IPL into the board's memory and will not be used in these instructions. For more details on installing the IPL without u-boot, see the release notes for the OMAP3530 Beagle Board. The NAND IPL imagenand-ipl-am3517evm.binwill be installed into the board's NAND flash from SD card via u-boot. This IPL is padded to 24K. The following steps describe how to generate the ipl-am3517evm.bin and nand-ipl-am3517evm.bin files:
#!/bin/sh
# script to build a binary IPL and boot image for the TI AM3517 EVM board
set -v
# Convert IPL header into Binary format
${QNX_HOST}/usr/bin/ntoarm-objcopy --input-format=elf32-littlearm --output-format=binary ../src/hardware/ipl/boards/am3517evm/arm/le/boot_header.o ./tmp-boot-header.bin
# Convert IPL into Binary format
${QNX_HOST}/usr/bin/ntoarm-objcopy --input-format=elf32-littlearm --output-format=binary ../src/hardware/ipl/boards/am3517evm/arm/le/ipl-am3517evm ./tmp-ipl-am3517evm.bin
# Cat boot header and ipl together
cat ./tmp-boot-header.bin ./tmp-ipl-am3517evm.bin > ./tmp-header-ipl-am3517evm.bin
# Pad Binary IPL to 24K image, this is the image used by boot from UART
mkrec -s24k -ffull -r ./tmp-ipl-am3517evm.bin > ./ipl-am3517evm.bin
# Pad Binary IPL with Header to 24K image, this is the image to put on NAND and boot from NAND
mkrec -s24k -ffull -r ./tmp-header-ipl-am3517evm.bin > ./nand-ipl-am3517evm.bin
# clean up temporary files
rm -f tmp*.bin
echo "done!!!!!!!"
Step B: Install NAND IPL image from u-boot#1. The steps above describe booting to u-boot from an SD card. Copy nand-ipl-am3517evm.bin to the SD card and boot to u-boot. Hit CTRL-C if necessary to stop the boot sequence at the u-boot prompt. 2. Issue the following commands from u-boot to install the IPL to NAND:
3. Configure the dipswitches on the eval board so that it boots from NAND. S7-1, S7-2, and S7-3 should all be off. 4. Reset the board. The following text should appear: QNX Neutrino Initial Program Loader for Texas Instruments AM3517 EVM Board Commands: Press 'D' for serial download, using the 'sendnto' utility Press 'F' to boot an OS image from NAND flash Press 'U' to Copy an OS image to NAND flash Press 'I' to Update the IPL Step C: Download OS image #1. Start the QNX Momentics IDE on the host. 2. Open a terminal server window. See the IDE documentation for details. 3.Type U to copy the OS image to the NAND flash. 4. In the terminal server window, click the "send file" button in the upper left corner. A popup window will open. Type or browse the correct image file name (ifs-am3517evm.raw) in the "Filename" box and sendto as the proctocol. Click OK to start the download on the host side. 5. After the download process finishes, You should see output similar to the following: Press 'D' for serial download, using the 'sendnto' utility Press 'F' to boot an OS image from NAND flash Press 'U' to Copy an OS image to NAND flash Press 'I' to Update the IPL send the ifs now... download OK... Writing IFS image to NAND flash from block 4 ...... Upgrade IFS OK... Commands: Press 'D' for serial download, using the 'sendnto' utility Press 'F' to boot an OS image from NAND flash Press 'U' to Copy an OS image to NAND flash Press 'I' to Update the IPL 6. Type F ' to boot an OS image from NAND flash. You should see output similar to the following: Reading from NAND flash ...... Found image @ 0x84000008 Jumping to startup @ 0x80100480 CPU0: L1 Icache: 256x64 CPU0: L1 Dcache: 256x64 WB CPU0: L2 Dcache: 4096x64 WB CPU0: VFP 410330c1 CPU0: 411fc087: Cortex A8 rev 7 500MHz System page at phys:80011000 user:fc404000 kern:fc404000 Starting next program at vfe046e74 cpu_startnext: cpu0 -> fe046e74 VFPv3: fpsid=410330c1 coproc_attach(10): replacing fe068c84 with fe068444 coproc_attach(11): replacing fe068c84 with fe068444 Welcome to QNX Neutrino 6.4.1 on the Texas Instruments AM3517 EVM (ARMv7 Cortex-A8 core)
Creating a new flash partition#
You should now have a /fs0p1 directory which you can copy files to.
Summary of driver commands#The following tables summarize the commands to launch the various drivers.
General Notes#
Known issues for this BSP#
