| wiki4286: Nto641FreescaleI.mx51EvkTrunkReleasenotes (Version 11) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Release Notes for the QNX Neutrino 6.4.1 BSP for Freescale i.MX51 EVK 1.0.0#System requirements#Target system
Host development system
System Layout#The tables below depict the memory layout for the image.Memory layout
The interrupt vector table can be found in the buildfile located at src/hardware/startup/boards/mx51evk/build
Getting Started#Starting Neutrino#Step 1: Build the BSP Copy or transfer the IFS image into your tftp server's directory.
Step 2: Connect your hardware
Then, apply power to the target. You should see output similar to the following:
++Booting from SDHC0
Bus Width: 1
Card initialization successful!
Actual capacity of the card is 3866624KB
Redboot uses 2097152KB
... Read from 0x1fee0000-0x1ff00000 at 0x00040000: .
... Read from 0x1fed3000-0x1fed4000 at 0x0005f000: .
PMIC ID: 0x000041d0 [Rev: 2.0]
Initializing SPI-NOR flash...
FEC LAN8700 PHY: ID=7c0c4
FEC: [ HALF_DUPLEX ] [ disconnected ] [ 10M bps ]:
Ethernet mxc_fec: MAC address 00:04:9f:00:ea:c2
IP: 172.18.74.117/255.255.255.0, Gateway: 172.18.74.1
Default server: 172.18.80.127
Reset reason: Power-on reset
fis/fconfig from MMC
Boot switch: INTERNAL
EXPANSION: SD/MMC-0
RedBoot(tm) bootstrap and debug environment [ROMRAM]
Non-certified release, version FSL 200938 - built 11:47:45, Sep 15 2009
Platform: MX51 Babbage (Freescale i.MX51 based) PASS 3.0 [x32 DDR]. Board Rev 2.
5
Copyright (C) 2000, 2001, 2002, 2003, 2004 Red Hat, Inc.
Copyright (C) 2003, 2004, 2005, 2006 eCosCentric Limited
RAM: 0x00000000-0x1ff00000, [0x000953e0-0x1fed1000] available
FLASH: 0x00000000 - 0x80000000, 16384 blocks of 0x00020000 bytes each.
RedBoot>
Step 3: Setup the environment At the RedBoot prompt, issue the fconfig command to change the current environment. The current configurations will be displayed; change the configuration if you want. Run script at boot: false Use BOOTP for network configuration: false Gateway IP address: 192.168.1.1 Local IP address: 192.168.1.202 Local IP address mask: 255.255.255.0 Default server IP address: 192.168.1.15 Board specifics: 0 Console baud rate: 115200 Set eth0 network hardware address [MAC]: false Set FEC network hardware address [MAC]: false GDB connection port: 9000 Force console for special debug messages: false Network debug at boot time: false Default network device: mxc_fec Step 4: Boot the IFS image Once the above setup is complete, reset the board and you can run the load command at the RedBoot prompt to download the image: load -r -b 0x100000 ifs-mx51evk.raw; go 0x100000 Replace 192.168.1.15 with the IP address of your TFTP server and ifs-mx51evk.raw with the path of the image on the TFTP server. RedBoot will display the follow message and start downloading the boot image: Using default protocol (TFTP) If the image is successfully loaded RedBoot will display: Raw file loaded 0x00100000-0x00389fb7, assumed entry at 0x00100000 You also should see QNX Neutrino boot, followed by the welcome message on your terminal screen:
CPU0: L1 Icache: 512x64
CPU0: L1 Dcache: 512x64 WB
CPU0: L2 Dcache: 4096x64 WB
CPU0: VFP 410330c2
CPU0: 412fc081: Cortex A8 rev 1 800MHz
System page at phys:90011000 user:fc404000 kern:fc404000
Starting next program at vfe043df0
cpu_startnext: cpu0 -> fe043df0
VFPv3: fpsid=410330c2
coproc_attach(10): replacing fe0659e0 with fe0651a0
coproc_attach(11): replacing fe0659e0 with fe0651a0
Welcome to QNX Neutrino 6.4.1 on the i.MX51 EVK (ARM Cortex-A8 core) Board
Starting on-board ethernet with TCP/IP stack...
Starting I2C1 driver (/dev/i2c0)...
Starting I2C2 driver (/dev/i2c1)...
Starting SD1 memory card driver...
Starting SD2 memory card driver...
Starting watchdog
Starting SPI driver for CSPI (dev/spi0)...
Starting Enhanced SPI driver for ECSPI1(dev/spi1) ...
Starting Enhanced SPI driver for ECSPI2(dev/spi2) ...
Starting SSI Audio driver for SGTL5000...
"Mic In",0 - Capture Group
Capabilities - Volume Jointly-Capture Exclusive-Capture
Channels - Front-Left Front-Right
Volume Range - minimum=0, maximum=3
Channel 0 Front-Left - 0 ( 0%) Capture
Channel 1 Front-Right - 0 ( 0%) Capture
Starting USB Host driver...
Starting Graphics driver...
# Path=0 - FREESCALE MX35 e
target=0 lun=0 Direct-Access(0) - SD:2 SA04G Rev: 0.4
target=0 lun=0 Direct-Access(0) - SD:2 SD02G Rev: 4.1
You can test the OS simply by executing any shell builtin command or any command residing within the OS image (e.g. ls). Auto Display Detection#The i.MX51 EVM supports multiple output displays. This BSP's default build file produces an IFS that will auto detect which display is connected and configure video output for that display. The BSP checks for attached displays in the following order: WVGA LCD Display Panel VGA is the default and is selected if neither the LCD nor the DVI-D monitor are detected. Note that if both the DVI-D and LCD panel are attached, the display will be configured for the LCD. Also, to detect a DVI-D monitor it must be connected to the DVI connector on the i.MX51 EVM and the monitor must be turned on. Driver Command Summary#The following table summarizes the commands to launch the various drivers.
Some of the drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board. Startup, Watchdog, Configurable SPI, Enhanced Configurable SPI, Ethernet, and Graphics have additional details: Startup#startup-mx51evk [startup-options] Some modules aren't enabled after boot up, so you need to use command line options to startup to enable them. These options must be passed before any other startup options.
Note that both -d1 and -d2 must be specified to support auto display detection using the display-detect program. Ethernet#io-pkt-v4-hc -d mx51 mac=xxxxxxxxxxxx MAC address labelled on i.mx51 evk board must be provided with "mac" command line option. Audio#io-audio -d mx-mx51evk ssibase=0x83FCC000,tevt=29,tchn=1,revt=28,rchn=2,rate=48000,mixer=i2cdev=1:adr0cs=0:mclk=26000000 mix_ctl group "Mic In" capture=on
Note:
1.To start the audio system, you'll need to execute the I2C driver "i2c-mx35 --u1,1" first. 2.This audio driver sets "Line in " as the capture default device. i.MX51 EVK uses "Mic in " capture device.Please run "mix_ctl group "Mic In" capture=on" to set the capture device after the audio driver running. Graphics#PATH=/proc/boot:/sbin:/bin:/usr/sbin:/usr/bin display-detect io-display -dvid=0,did=0,deviceindex=# The display-detect program uses the i.MX51 EVM display hardware to detect the attached display and then replaces the '#' in the io-display command line with the selected displayindex using the following mapping:
The display.conf config file then maps these indexes 0-2 to driver config files imx51.conf, imx51-1.conf, and imx51-2.conf respectively to get the appropriate output display timing and configuration settings. Accelerated Graphics#An archive containing an experimental driver for the GPU (OpenVG & OpenGLES) can be found on the Foundry 27 graphics project: http://community.qnx.com/sf/go/projects.graphics/frs.imx51_gpu_driver Please obtain the latest version and follow the corresponding setup instructions.
Known Issues for This BSP#
