wiki2978: Nto640FreescaleMgt5200b1.0.0Releasenotes (Version 14)
Release Notes for the QNX Neutrino 6.4.0 BSP for Freescale Lite5200B and Media5200 1.0.0#
System requirements#
Target system
  • QNX Neutrino RTOS 6.4.0
  • Board version: Lite5200B or Media5200
  • MPC5200B processor (based on MPC603e series)
  • 32 MB flash on the Lite5200B / 64 MB flash on Media5200
Host development system
  • QNX Momentics 6.4.0
  • Terminal emulation program (Qtalk, Momentics IDE Terminal, tip, HyperTerminal, etc.)
  • RS-232 serial port and serial cable, or a USB-to-serial cable
  • Ethernet link
  • For other system requirements (e.g. disk, RAM), see the installation notes for QNX Momentics.
System Layout#
The tables below depict the memory layout for the image and for the flash.
Memory layout
ItemAddress
OS image loaded at: 0x00020000
Ethernet base address 0xf0003000 (IRQ: 69, 140)
USB base address 0xf0001000 (IRQ: 70)
PSC base address (Lite5200B) 0xf0002000 (IRQ: 65)
PSC base address (Media5200) 0xf0002c00 (IRQ: 68)
Flash layout for Lite5200B (U-Boot view)
Flash layout Flash start address Size
U-Boot 0xfff00000 1 MB
Empty 0xff500000 10 MB (variable)
OS Image 0xff080000 4.5 MB (variable)
IPL 0xff000000 512 KB
Empty 0xfe000000 16 MB
Flash layout for Lite5200B (IPL view)
Flash layoutFlash start addressSize
Empty 0xff000000 16 MB
U-Boot 0xfef00000 1 MB
Empty 0xfe500000 10 MB (variable)
OS Image 0xfe080000 4.5 MB (variable)
IPL 0xfe000000 512 KB
Flash layout for Media5200 (U-Boot or IPL view)
Empty 0xfe500000 26 MB (variable)
Empty 0xfc000000 32 MB
The interrupt vector table can be found in the buildfile located at src/hardware/startup/boards/mgt5200B/build
Getting Started#
Starting Neutrino#
Step 1: Build the BSP
You can build a BSP OS image from the source code or the binary components contained in a BSP package.
For instructions about building a BSP OS image, please refer to the chapter Working with a BSP in the Building Embedded Systems manual.
Note: This BSP will build a default OS image for the Freescale Media5200 board. If you need to build an OS image for the Freescale Lite5200B, you need to change the buildfile. The buildfile has commented-out sections for the Lite5200B. Simply uncomment them and comment out the Media5200 sections.
Step 2: Connect your hardware
  1. Setup the board. Refer to the manual for the correct default jumper settings to use.
  2. Connect one end of the serial NULL-modem cable to the J3 serial port.
  3. Connect the other end of the serial NULL-modem cable to the first available serial port of your host machine (e.g. ser1 on a Neutrino host).
  4. Connect an RJ-45 Ethernet cable to J6 (100/10 Mbit Ethernet RJ-45 connector).
  5. Connect the other end of the Ethernet cable to the Ethernet network where a TFTP server (which you'll use to transfer the boot image) exists.
On your host machine, start your favourite terminal program with these settings:
  • Baud: 115200
  • Bits: 8
  • Stop bits: 1
  • Parity: none
Then, apply power to the target board.
You should see output similar to the following if you are using the Lite5200B or Media5200:
U-Boot 1.1.3 (Jul 11 2005 - 16:46:38)
CPU:   MPC5200 v2.1 at 462 MHz
       Bus 132 MHz, IPB 132 MHz, PCI 33 MHz
Board: Freescale MPC5200 (Lite5200B)
I2C:   85 kHz, ready
DRAM:  256 MB
FLASH: 32 MB
PCI:   Bus Dev VenId DevId Class Int
        00  1a  1057  5809  0680  00
In:    serial
Out:   serial
Err:   serial
Net:   FEC ETHERNET
IDE:   Bus 0: OK
  Device 0: not available
  Device 1: not available
Type "run flash_nfs" to mount root filesystem over NFS
Hit any key to stop autoboot:  0
Step 3: Transfer the OS image to the target using the ROM monitor
  1. At the U-boot prompt, issue the following command to view the current environment:
    printenv
  2. Set the baud rate and follow the instructions:
    setenv baudrate 115200
  3. Set the local IP address (replace x.x.x.x with the desired IP address):
    setenv ipaddr x.x.x.x
  4. Set the IP address for your host TFTP server (replace x.x.x.x with the desired IP address):
    setenv serverip x.x.x.x
  5. Set the gateway address (replace x.x.x.x with the desired IP address):
    setenv gatewayip x.x.x.x
  6. Specify the image or fullpath to the OS image (on the host machine):
    setenv bootfile /full_path_to_image/image.raw
  7. Once the above setup is complete, save the environment to the onboard EEPROM:
    saveenv
  8. Copy the image from your host to the target:
    tftpboot loadaddr
    At this point you should see the ROM monitor download the boot image, indicated by a series of dots.
  9. Type:
    go loadaddr
You should now see the QNX Neutrino welcome message on your terminal screen:
Welcome to QNX Neutrino 6.4 on the Freescale Lite5200B / Media5200
Once the initial image is running, you can update the OS image using the network and flash drivers. For sample command lines, please see the "Summary of driver commands" section.
Starting the flash driver
  • To start the flash driver on the Lite5200B, enter the following command:
    devf-mgt5200 -s0xfe000000,32M
  • To start the flash driver on the Media5200, enter the following command:
    devf-mgt5200 -s0xfc000000,64M
Putting the IPL and OS image on the flash (Lite5200B)#
  1. Generate the IPL and OS image (using the method in "Step 2: Generate an OS image").
  • A
  • B
  1. C
Text coral.conf [Nto640FreescaleMgt5200b1.0.0Releasenotes/coral.conf]
Inactive Tab Versions Active Tab - left sideAssociations Inactive Tab - left sideAttachments (1) Inactive Tab - left sideBack LinksInactive Tab - right side
1Sort UpDate 2Sort DownAssociation 3Sort UpPosted By SortComment Association Type
No results found.
