Xilinx Zynq7000 ZC702 EVM Board Support Package#
This BSP supports the Xilinx Zync7000 All Programmable SoC, on the Xilinx ZC702 Evaluation Kit.
Releases#
Updated! QNX Neutrino 6.6.0 BSP#
| Date | Version | Prerequisites | User Guide | License(s) | Support | Provider | BSP |
| 2018-01-11 | 6.6.0 | QNX SDP 6.6.0 | here | Apache II | Experimental | QNX | here |
Features#
| Feature | Planned Availability | Format | Notes |
| IPL | Completed | SRC | |
| Startup | Completed | SRC | |
| Serial | Completed | SRC | |
| I2C | Completed | SRC | |
| SPI | Completed | SRC | |
| CAN | Completed | SRC | |
| QSPI NOR flash | Completed | SRC | |
| USB EHCI Host | Completed | BIN | |
| Ethernet | Completed | SRC | |
| RTC | Completed | SRC | |
| SD/MMC | Completed | SRC | |
| FPGA utility | Completed | SRC | |
| XADC utility | Completed | SRC | |
| OCM utility | Completed | SRC | |
| GPIO library | Completed | SRC | |
| DMA library | Completed | SRC | |
QNX Neutrino SDP 6.6 Change History#
January 11, 2018#
- SDMMC: updated driver to new devb-sdmmc framework
- Networking: added getmac-i2c utility to read Ethernet MAC from I2C EEPROM. Removed MAC address spoofing when EEPROM read fails.
- QSPI-Flash: Errata AR# 47575 fix. Support for 4-byte addressing
- UART: support for multiple interfaces
- I2C: fixed i2c send issue, fixed clock issue
- SPI: fixed Chip Select behavior
- GPIO Lib: various bug fixes
August 20, 2014#
QNX Neutrino 6.5.0 Service Pack 1 BSP#
| 2014-08-18 | 6.5.0 SP1 | QNX Momentics 6.5.0 SP1 | here | Apache II | Experimental | QNX /Adeneo | here |
Features#
QNX Neutrino 6.5.0 SP1 Change History#
August 18, 2014#
- updated GIC interrupt callout included in BSP, to reduce potential interrupt latency
January 24, 2014#
- include prebult boot.bif and fsbl.elf in BSP
- documentation updates to clarify process for building IPL binary with different versions of Xilinx tools
- minor fix for an incorrect #define in the startup code
June 14, 2013#
- add QSPI NOR flash driver source and DMA Library source
- fix for ClockPeriod() issue (use global timer)
- fix for ClockCycles() issue
- update to enable FPGA access after FPGA is programmed
May 15, 2013#
- update to address minor issues:
- don't start watchdog timer by default in build file
- include pre-built DMA library
- remove duplicate wdtkick utility
May 14, 2013#
Release 1.00#
Search Keywords: xilinx, zynq, zynq-7000, zynq7000, zc702, zc706, AP SoC, arm, cortex-a9, fpga
