| wiki5500: DevgIntelhd.so | ||||||||||||||||||||||||||||||
Installation and Release notes for USB stack.#Updated QNX 4 USB stack is a backport of the QNX 6.5.0 USB stack. It updates support for OHCI, UHCI and EHCI chipsets and provides extended hardware support.
Changes in version 2.00K#- fixed error with the release of global memory segments (gdts). This error could lead to a gdts leak and depletion of this resource after ~10-15 restarts of the Fsys.umass;- fixed problem with system freeze after io-usb start on several OHCI controllers; - fixed problem (on most systems) with USB keyboards or USB mice freeze if the USB keyboard and USB mouse are used at the same time and Net and io-usb are sharing one interrupt line. Archive content#The USB 2.0 driver archive for the QNX 4 contains:
Installation notes#To install USB stack driver: 1. Download the archive with USB stack and drivers. 2. Unpack the driver: # zcat QNX425-USB-20120214.tar.gz | tar x 3. Compare the cksum results with the checksum on patch/QNX425-USB-20120214/cksum.txt file. # cksum patch/QNX425-USB-20120214/bin/* 4. Backup the existing USB stack components. If you wish to keep a copy of the existing driver, you'll need to save them to a safe location first, to prevent them from being overwritten during installation. # cp -v /bin/io-usb /bin/io-usb.`date +"%y%m%d_%H%M%S"` 5. Copy the updated usb stack components to the /bin directory: # cp -v patch/QNX425-USB-20120214/bin/* /bin 6. Make sure that the binaries are executable and that the file's owner and group are correct: # chmod 775 /bin/io-usb |
