| wiki3849: Nto640TiDrx45x1.0.0Releasenotes (Version 3) |
Release Notes for the QNX Neutrino 6.4.0 BSP for Texas Instruments DRX45X EVM (J1DDR) 1.0.0#System requirements#Target system#
Host development system#
Getting Started#Step 1: Connect your hardware#Connect the serial cable to the UART0 serial port (P2) of the DRX45X board and to the first serial port on the host machine (e.g. ser1 on a Neutrino host).Note: If you have a Neutrino host with a serial mouse, you may have to move the mouse to the second serial port on your host, because some terminal programs require the first serial port. Step 2: Build the BSP#You can build a BSP OS image from the source code and the binary components contained in a BSP package. For instructions about building a BSP OS image, please refer to the chapter Working with a BSP in the Building Embedded Systems manual. Step 3: Transfer the OS image to the target #Boot OS images by ROM monitor#1. On your host machine, start your favorite terminal program with these settings:
2. Start your target. You should see output similar to the following:
U-Boot 1.1.3 (Apr 29 2009 - 11:26:47)
U-Boot code: 81080000 -> 810978DC BSS: -> 8109C5D4
RAM Configuration:
Bank #0: 80000000 128 MB
******************** J1DDR version 0.03 *******************
qjwang@ti.com
ARM Clock : 408MHz DSP Clock : 552MHz
SDRAM Clock : 110MHz DDR Clock : 192MHz
SPANSION NOR Flash: 64 MB
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 3
Press any key to stop autobooting, and then you'll see the J1DDR prompt:
J1DDR #
On your target, type the following, filling in the appropriate IP addresses and ifs file:
J1DDR # setenv netmask 255.255.240.0
J1DDR # setenv ipaddr 10.42.101.242
J1DDR # setenv gatewayip 10.42.96.1
J1DDR # setenv serverip 10.42.98.211
J1DDR # setenv 'bootcmd tftpboot 80100000 ifs-drx45x.raw;go 80100000'
J1DDR # saveenv
Restart your target. You should see output similar to the following:
RAM Configuration:
qjwang@ti.com
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
Using MAC Address 00:0E:99:02:60:E9
TFTP from server 10.42.98.211; our IP address is 10.42.101.242
Filename 'ifs-drx45x.raw'.
Load address: 0x80100000
done
Bytes transferred = 2194176 (217b00 hex)
## Starting application at 0x80100000 ...
Welcome to QNX Neutrino trunk on a TI DRx45x EVM
Boot OS images by IPL#Note: Before burning the IPL, you might want to save the first 1 MB of flash in order to save the ROM monitor. 1. Modify the build file for IPL to get the binary OS image and run `make clean all` in the BSP's images directory to create a combined IPL/OS image to use when burning the flash. # make clean all 2. Download the ipl-ifs-drx45x.bin image to your target board, /dev/shmem/ipl-ifs-drx45x.bin. 3. Make sure the target can read the image you want to copy, and then execute the following commands in the Neutrino shell to burn the IPL-IFS images to flash: # devf-generic -s0x20000000,64M # flashctl -p/dev/fs0 -l6M -ve # cp -V /dev/shmem/ipl-ifs-drx45x.bin /dev/fs0 4. Reboot the target. You should see output similar to the following: Welcome to QNX Neutrino on the Texas Instruments EVMDRX45X board. Commands: Press 'S' for serial download, using the 'sendnto' utility Press 'F' to boot an OS image in flash 5. When IPL prompt come up, Either press s to transfer the OS image serially using sendnto, or press f to scan the flash for an os image. Note: When booting serially, images larger than 6 MB won't load unless you first modify the IPL source. Step 4: Start working with Neutrino OS#You can test the OS simply by executing any shell builtin command or any command residing within the OS image (e.g. ls). Once the initial image is running, you can update the OS image using the network and flash drivers. For sample command lines, please see the “Summary of driver commands” section. Known issues for this BSP#Note: Please check the version of these release notes on the website for the most up-to-date information.
Summary of driver commands#The driver command lines below are specific to the TI DRX45X EVM board. Note: Some of the following drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board. Startup:#Command:startup-drx45x -L 0x87e00000,0x200000 -v Serial:#Command:devc-ser8250-jacinto -e -F -S -b 115200 -c24000000/16 0x01c20000^2,43 Required binaries:
Flash(NOR):#Command:devf-generic -s0x20000000,64M Required binaries:
SPI:#Command:spi-master -d dra446 base=0x01C4cc00,irq=31,edma=-1,clock=24000000 Required binaries:
Required libraries:
I2C:#Command:i2c-dm6446 -p0x01C21000 -i39 --u0 Required binaries:
USB:#Command:io-usb -d jacinto ioport=0x01c42000,irq=2 Required binaries:
Required libraries:
Ethernet:#Command:io-pkt-v4 -dsmc9000-jacinto ioport=0x2a000000,irq=108 Required binaries:
Required libraries:
Block:#Command:devb-eide-dm644x blk cache=12M Required binaries:
Required libraries:
SD:#Command:
devb-mmcsd-drx45x cam quiet mmcsd ioport=0x01C50000,irq=16,dma=20,dma=21 blk cache=2m (SD0 on the Jacinto base board)
devb-mmcsd-drx45x cam quiet mmcsd ioport=0x01C41800,irq=54,dma=27,dma=28 blk cache=2m (SD1)
devb-mmcsd-drx45x cam quiet mmcsd ioport=0x01c41c00,irq=42,dma=29,dma=30 blk cache=2m (SD2)
Required binaries:
Required libraries:
Note: the sd device can be mounted with "mount" command or "automount" options. For example: Using "mount" command: devb-mmcsd-drx45x cam quiet mmcsd ioport=0x01C50000,irq=16,dma=20,dma=21 blk cache=2m
Using "automount" options
Audio:#Command:io-audio -d dra44x-jacintoNote: This driver must be started after the I2C interface 0 is active on i2c0 (i.e. i2c-dm6446 -p0x01C21000 -i39 --u0). Required binaries:
Required libraries:
ETFS NAND flash#Command when using 16-bit nand chips:fs-etfs-jacinto -Dwidth=16 -m /fs/etfs Command when using 8-bit nand chips: fs-etfs-jacinto -Dwidth=8 -m /fs/etfs You should then see /dev/etfs1 and /dev/etfs2 partitions. Required binaries:
To erase and format the NAND flash partition:
Note: You have to change the S1 config switch on the base board and start the driver with the correct command line options depending on the width of the chip. Graphics:#Command:io-display -dvid=0,did=0 Required binaries:
Required libraries:
Required config files:
Note: For more information about these commands, see the Neutrino Utilities Reference. About graphics#The graphics driver only supports the secondary digital display interface (VPSS1) with a single display output. The driver was tested with the LG Philips LB080WV3-B1 digital LCD. Using other displays might result in undesired behavior. The LCD should be connected to the DC5 connector found at the bottom of the base board. The VPSS controller supports the following layers or “OSD windows”:
You can control the following features for all layers:
The OSD windows can support the follow features:
You can enable or configure OSD Rectangular Cursor support using drx45x.conf. Note: Caveats:
Optional graphics memory management#The DRX45X EVM (J1DDR) has two memory buses (EMIFA, EMIFB). We've found that for certain graphics operations, performance is improved if the source and destination surfaces are on separate EMIFs. Creating a flash partition#1. Enter the following command to start the flash filesystem driver: devf-generic -s0x20000000,64M 2. Erase the flash, except for the first 6 MB: Note: Because the ROM monitor or IPL/OS image are in the first 6 megabyte of flash , you may not want to erase them. Use the -l (length) and -o (offset) options to avoid these areas. flashctl -p/dev/fs0 -o6M -l58M -ve 3. Format the partition: flashctl -p/dev/fs0p0 -o6M -l58M -vf 4. Slay and then restart the driver to mount the new partition: slay devf-generic devf-generic -s0x20000000,64MYou should now have a /fs0p0 and /fs0p1 directory automounted. |
