~Advantech ~SOM-6760 Board Support Package#
This BSP supports the Advantech SOM-6760 board.
Note that this board is out of production and is no longer available from Advantech.#
Releases#
QNX Neutrino 6.4.0#
Fastboot IPL Source Coming Soon!
Features#
| Feature | Planned Availability | Format | Notes |
| High Definition Audio | Completed | BIN | . |
| IPL | Completed | BIN | “Cold Start” IPL, programmed to EEPROM. |
| Startup | Completed | SRC | . |
| Serial | Completed | SRC | . |
| Flash | Completed | SRC | Intel FWH NOR flash |
| Ethernet | Completed | BIN | Intel 82551QM Ethernet Controller. |
| EIDE | Completed | BIN | . |
| SMbus Resource Manager | Completed | SRC | . |
| USB | Completed | BIN | EHCI and UHCI. |
| Graphics | Completed | BIN | Intel SCH US15W Poulsbo Graphics Controller (GMA 500). |
| MMC / SD | Completed | SRC | . |
| PCI / PCIe | Completed | SRC | PCIe devices are supported only in PCI legacy mode. |
Some of these drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board.
QNX Neutrino 6.4.0 Change History#
Trunk#
- Created from QNX Neutrino 6.3.2 BSP for Intel Crownbeach 1.0.0
- Built using the latest 6.4.0 toolchain
