LiPPERT CoreExpress Board Support Package#
This BSP supports the LiPPERT CoreExpress board.
Releases#
QNX Neutrino 6.4.0#
Fastboot IPL Source
Features#
| Feature | Planned Availability | Format | Notes |
| High Definition Audio | Completed | BIN | . |
| IPL | Completed | BIN | “Cold Start” IPL, programmed to EEPROM. |
| Startup | Completed | SRC | . |
| Serial | Completed | SRC | . |
| Flash | Completed | SRC | Intel FWH NOR flash - SST devices only |
| Ethernet | Completed | BIN | Intel 82551QM Ethernet Controller. |
| EIDE | Completed | BIN | . |
| SMbus Resource Manager | Completed | SRC | . |
| USB | Completed | BIN | EHCI and UHCI. |
| Graphics | Completed | BIN | . |
| MMC / SD | Completed | SRC | . |
| PCI / PCIe | Completed | SRC | PCIe devices are supported only in PCI legacy mode. |
Some of these drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board.
QNX Neutrino 6.4.0 Change History#
Trunk#
- Created from QNX Neutrino 6.3.2 BSP for Intel Crownbeach 1.0.0
- Built using the latest 6.4.0 toolchain
