| wiki3438: NtotrunkBroadcomBcm91x86TrunkReleasenotes | ||||||||||||||||||||||||||||||||||||||||
Release Notes for the Broadcom BCM91x80 Evaluation Platform BSP#System requirements#Target system#
Host development system#
Getting Started#Starting Neutrino#Step 1: Build the BSP Step 2: Connect your hardware
Apply power to the target board. You should see output similar to the following: CFE version 1.2.3 for BCM91480B (64bit,MP,BE,MIPS) Build Date: Thu Jun 2 13:02:05 PDT 2005 (khinzaw@hardy.sj.broadcom.com) Copyright (C) 2000,2001,2002,2003,2004,2005 Broadcom Corporation. [AREN] Initializing Arena. Initializing PCI. [normal] [PCIH] PCI[0] bus 0 slot 0/0: configuring bus for 133MHz PCI-X [PCIB] [PCIS] PCI[0] bus 0 slot 0/0: SiByte, Inc. BCM1480 PCI-X Host Bridge (host bridge, rev 0x01) [PCIH] HT maxima: 700MHz, 16 bits [PCIB] PCI[1] bus 0 slot 0/0: secondary bad or never ready PCI[1] bus 0 slot 1/0: secondary bad or never ready [PCIS] PCI[1] bus 0 slot 0/0: SiByte, Inc. BCM1480 HyperTransport Bridge (Secondary) (PCI bridge, rev 0x01) PCI[1] bus 0 slot 1/0: SiByte, Inc. BCM1480 HyperTransport Bridge (Secondary) (PCI bridge, rev 0x01) PCI[1] bus 0 slot 2/0: SiByte, Inc. BCM1480 HyperTransport Bridge (Secondary) (PCI bridge, rev 0x01) PCI[1] bus 0 slot 4/0: SiByte, Inc. BCM1480 HyperTransport Host Bridge (host bridge, rev 0x01) PCI[1] bus 3 slot 1/0: Advanced Micro Devices (PLX) HT7520 PCI-X Tunnel (PCI bridge, rev 0x12) PCI[1] bus 3 slot 1/1: Advanced Micro Devices (PLX) HT7520 PCI-X IOAPIC (8259 PIC system, interface 0x10, rev 0x01) PCI[1] bus 3 slot 2/0: Advanced Micro Devices (PLX) HT7520 PCI-X Tunnel (PCI bridge, rev 0x12) PCI[1] bus 3 slot 2/1: Advanced Micro Devices (PLX) HT7520 PCI-X IOAPIC (8259 PIC system, interface 0x10, rev 0x01) PCI[1] bus 5 slot 2/0: Intel 82557 Fast Ethernet LAN Controller (ethernet network, rev 0x0c) [DEVI] Initializing Devices. BCM91480B board revision 1 BCM91480B configuration switches: 0xc1018 sbeth: found phy 1, vendor 000818 part 0B sbeth: found phy 2, vendor 000818 part 0B sbeth: found phy 3, vendor 000818 part 0B sbeth: found phy 4, vendor 000818 part 0B PCIIDE: 0 controllers found CPU: 1480 A1 (pass1), 4 cpus L2Cache: 1MB SysCfg: 0000000060752380 [PLL_DIV:14, SW_DIV:4, CCNUMA:disable, IOB_DIV:CPUCLK/4] Memory controller #0: 233MHz Memory controller #1: 140MHz Switch Clock: 350MHz CPU type 0x1041100: 700MHz Total memory: 0x40000000 bytes (1024MB) Total memory used by CFE: 0x8FE7B000 - 0x8FFFFC60 (1592416) Initialized Data: 0x8FEEF2C0 - 0x8FEFCB50 (55440) BSS Area: 0x8FEFCB50 - 0x8FEFDC50 (4352) Local Heap: 0x8FEFDC60 - 0x8FFFDC60 (1048576) Stack Area: 0x8FFFDC60 - 0x8FFFFC60 (8192) Text (code) segment: 0x8FE7B000 - 0x8FEEE3F0 (472048) Boot area (physical): 0x0FE3A000 - 0x0FE7A000 Relocation Factor: I:F027B000 - D:F027B000 [ENVI] [CFE ] CFE> Step 3: Setup the environment and boot the IFS image You can use TFTP download (the default) or serial download to transfer the image from your host to the target. On your target, type the following, filling in the appropriate IP addresses and ifs file: CFE> ifconfig eth0 -addr=TARGET_IP CFE> boot -elf HOST_IP:/full_path_to/ifs-bcm91x80.elf Where TARGET_IP is the IP address of the BCM1x80 Evaluation Platform, HOST_IP is the IP address of the host machine and the full path should be specified for the ELF image.
Summary of driver commands#The driver command lines below are specific to the Broadcom BCM1x80 Evaluation Platform. See the online docs for each driver for additional command-line options and other details.
Some of the drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board. |
